How To Add A Heat Register - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 09:57 AM   #1
how to add a heat register
I want to add a heat register to the next room across from the current register How do I go through the wall and extend the furnace duct work?
Joyce H is offline   Reply With Quote
Old 10-23-2011, 12:11 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Can you take some pictures of the areas so we know what you're working with?
I can tell you, I've done it hundreds of times, but I need to see the space, all of it and everywhere, for best advice and results.
Doc Holliday is offline   Reply With Quote
Old 10-25-2011, 10:03 AM   #3
Rewards Points: 5,326
Cut open a vent sized hole.
Install blocking above the hole and seal it with caulking..
Cut the duct off so the turn into the other room is removed.
Fill in the gaps around the duct going down.
Install the vent louvers.
The hot air will fill the cavity and be pushed out into the 2 rooms.
Not an elegant solution, but one that will work.
Ron
B. Franklin 1759
No Aux heat with American Std HP/Trane AH and Honeywell IAQ FREEZING!!!! JackBP HVAC 3 12-18-2010 03:50 AM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
Goodman GPH1336H21AA heat strip connection jrajra HVAC 2 09-02-2010 05:52 PM
Help..Emergency Heat Running All the Time KatieB HVAC 4 02-25-2009 05:55 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
