The House Won't Fall If I Remove These...Right? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-29-2008, 08:41 AM   #1
Midicat's Avatar
Rewards Points: 24
I have started to work on our 44 yr old bungalow purchased in the fall last year. The first thing to do is remove the 12" x 12" paper board tiles from the ceiling and then the strapping that was used to staple them to. The straps are 2" x 2" and spiked in four places to the floor joists above. I have started removing the 2" x 2" and I thought I should double check that they weren't also there to maintain spacing between the floor joists. In other words, they aren't structural. I'll post pics.
Thanks In Advance.
Thomas
The House Won't Fall If I Remove These...Right?-dsc04588.jpg   The House Won't Fall If I Remove These...Right?-dsc04589.jpg   The House Won't Fall If I Remove These...Right?-dsc04590.jpg
Midicat is offline   Reply With Quote
Old 03-29-2008, 08:51 AM   #2
ICF Construction
No, they are not structural, you can remove them without issue. Someone could have used 1x2 for those tiles originally.
If you are not planning on drywalling the ceiling anytime soon I would leave one row under the cross bridging, helps keep the ridgidity in the floor.
Chris
Chris Johnson is offline   Reply With Quote
Old 03-29-2008, 09:20 AM   #3
Midicat's Avatar
Rewards Points: 24
That's great, thanks Chris.
Thomas
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Sewage Under House: How To Remove Smell rajivsab Plumbing 5 11-27-2007 07:31 PM
Sewage Under House: How To Remove Smell?? rajivsab General DIY Discussions 1 11-25-2007 01:42 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
