Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-21-2010, 11:55 PM   #1
House trim has rotted my siding
After I replace the plywood siding, I was wondering how to replace the the trim so the rot doesn't begin again. So far my best choice seems to be attaching with screws and using washers as spacers between the trim and siding. Anyone with other ideas? This is a 28 year old house.
House trim has rotted my siding-img_5218.jpg   House trim has rotted my siding-img_5268.jpg
ovahimba is offline   Reply With Quote
Old 01-22-2010, 12:26 AM   #2
jlhaslip's Avatar
those belly bands need to have flashing over them so the water doesn't get behind it.
if you simply space them off the wall the water will get into the joint and wreck the framing
(or worse)
possibly a rabbet at the bottom to 'self flash' the lower sheets?
jlhaslip is offline   Reply With Quote
Old 01-22-2010, 01:22 AM   #3
Tom Struble's Avatar
thats the best advice,is there sheathing under the siding?
Tom Struble is offline   Reply With Quote
Old 01-22-2010, 12:12 PM   #4
I'd move the board down to the "Z" flashing interface and include the flashing, jlhaslip suggested. No sense having two flashings that close together.
Ron
Old 01-22-2010, 12:59 PM   #5
I was trying to avoid having to use flashing on top of the trim, all the extra work, but it seems to be the consensus here for a lasting result.
The 3/4" plywood siding has no sheathing behind it so I'll need vapor barrier as well. Here's a photo of some siding I removed for a deck ledger.
Thanks for the tip on the rabbet; it would at least maintain a clean look from below. I think the trim needs to go on at the same time I put on new siding to get the water barriers properly positioned.
Old 01-22-2010, 02:58 PM   #6
many times with that type of siding and trim there is a very good chance water can leak in around windows,check that area very carefully...good luck
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Aluminum trim falling off my house! clueless19 Building & Construction 4 05-04-2009 11:18 AM
Pressure washing painted houses nightman General Discussion 6 02-05-2008 09:23 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
