House On Slab - Water Problems - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-31-2015, 05:45 PM   #1
Rewards Points: 14
House on Slab - Water Problems
Greetings all,
Could really use some advice here. Got a house in Shelton, WA... where it rains a lot. Its built on slab foundation, which extends roughly 10" beyond wall in the back and front, and Several feet on the West side (east side protected by carport).
As you can see in attached photos, when it rains a lot water accumulates on edge of slab, and finds its way into the house. Hard to see under the leaves, but there is a french drain that runs along the back side of foundation, and exits on the side of house (attached photo shows where it exits). I already replaced the drywall on the inside, which all had moisture damage. I intend to also replace the external siding. On the side of the house, you can see that i already put some flashing... 4" x 4".. which goes up 4" behind the new siding i put on. I glued it on pretty well. But i still worry water will find its way between the flashing and concrete. But not sure what more i can really do. On the back side.. i'm tempted to get some 18" flashing.... bend it so 4" goes behind the new siding... across the 10" of slab, and bends over the side. But even then i worry water could wick up behind the flashing.
Any suggestions greatly appreciated!
I've been wondering if there is some way that once i remove the siding... before laying down a new pressure treated wood along slab.... if i could pour some kind of concrete lip that elevates higher than the rest of the slab excess... and so the wood is above. Not sure if this is feasible, practical, or even necessary. Help!
House on Slab - Water Problems-backside-house.jpg   House on Slab - Water Problems-side-flashing.jpg   House on Slab - Water Problems-french-drain-exit.jpg
gavroche is offline   Reply With Quote
Old 12-31-2015, 06:22 PM   #2
Property Mgt/Maint
Rewards Points: 354
You definitely have a bad drainage situation there. All of the surrounding grade needs to be lower than the surface of slab by about 6 inches and then tapered away from the house. Short of that you need new drain tile installed around the perimeter.
The flashing may help shed some water coming down the side of wall but will do little if you have water puddling over the slab. Managing the water runoff is where I would concentrate my efforts.
Yodaman is online now   Reply With Quote
Old 12-31-2015, 09:22 PM   #3
DIY staff
Rewards Points: 7,174
That's just a bad design any way you look at it
YodaMan summed up the solutions---lower the grade---get that slab covered so it sheds water --or tapered to drain---
Find the original builder and slap him---he should not be hard to spot--his rain coat will be tucked into his pants.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Thunder Chicken (01-02-2016), Trillium (01-02-2016)
Old 01-01-2016, 05:22 PM   #4
Rewards Points: 14
haha.... yea, it was built back in the 70s... but i'm pretty sure it was raining just as much then as it is now. so not too well thought out.
I'm not sure when the prior owner put in the french drain, but it seems to help. we recently had a ton of downpour, and the water was draining ok. but a bit of water still soaks the slab.... mostly from wind blowing it to the wall. I'm thinking of extending the eaves another foot or two over the side when i redo the roof next spring.
1) i want to do as you suggested about lowering the grade. i was thinking of lowering it a bit, and putting small retaining wall about 3-4 feet from the slab (i can't go farther as there is a large Madrona (beast of a tree)... and putting a new french drain there. Retaining wall would help with leave buildup coming down the hillside perhaps.
2) should i get the 16-20" flashing, and bend it so i got 4-6" behind the siding, and then across the 10" of slab, and then bent over the side of slab....? Of course.... i'd need almost a 30' stretch... and i would have to hand bend it, so it would not be a perfect looking job.
3) so can i install that tiling you are talking about (got a link to what you are referring to?) over top of that flashing? or is it better do it a different way...?
4) i was looking at some of that hardiboard type siding that's a composit/concrete combination, in lieu of the wood siding. but from the reviews of it that i've read, if you don't install it just perfect (nail type, sealing the nail holes, etc...) that it could be worse off than just normal wood siding.
Thanks!
Old 01-01-2016, 07:55 PM   #5
Property Mgt/Maint
Rewards Points: 354
quick primer on drain tile or french drains, google either and you can see many examples
http://www.seepage.com/learning-cent...ain-tile-works
Your french drains are the right idea just not done well. The whole system should have been much lower to allow water to settle rapidly below the slab surface in liue of washing up on the slab. The small pea stone on the surface is too small. And the surface of the stone is covered with leaves and dirt. Hinders the water seepage into the drain pipe and thus it washes up on your slab.
Here is a example of a very well done system. Maybe a little overkill for your project but it is your house!
https://en.wikipedia.org/wiki/French...chDrain-02.jpg
Old 01-02-2016, 12:51 PM   #6
Rewards Points: 1,036
Thanks!
Use a weep screed and/or weep screed deflector but as others have said you need to fix the grade first you should essentially have a drip edge at the bottom of your siding causing the water to drip away from the house instead of running down.
Mingledtrash is offline   Reply With Quote
Old 01-02-2016, 12:56 PM   #7
your house is designed badly sorry here is a detail showing how your siding should be above grade.
The Following 3 Users Say Thank You to Mingledtrash For This Useful Post:
joecaption (01-03-2016), oh'mike (01-02-2016), Yodaman (01-21-2016)
Old 01-02-2016, 09:53 PM   #8
Rewards Points: 112
To get something on the house that will not rot from water at the base of the wall, take off the bottom six inches or so of siding, put a Z-flashing under the siding edge, and put a 6" or so solid PVC board in place of the removed siding. A board in that application is called 'water table' trim.
See http://www.hammerzone.com/archives/e..._table/pvc.htm for an example.
You can also put a piece of flashing at the very bottom, spilling onto the concrete. This fix takes care of the rotting bottom of the siding, it doesn't prevent water from seeping in between the crack between the concrete and the bottom of the the 2x framing. I'd caulk that with silicone before putting the flashing and water table on.
Make sure you have gutters wherever you can put them, with piping to carry that water away, and proper grading to keep water away from the house.
ChuckF. is online now   Reply With Quote
Old 01-16-2016, 08:01 PM   #9
Rewards Points: 1,418
Why would your 18 inch flashing (like this) not work? This is the same thing that roofers use where a first story roof (such as a garage) meets a second story house wall.
(For the roof they use an L shape instead of the Z shape shown.)
The Following User Says Thank You to AllanJ For This Useful Post:
oh'mike (01-17-2016)
Old 01-21-2016, 01:28 AM   #10
Rewards Points: 402
One thing is pretty clear; you have a bad drainage situation out there. As far as the flashing is considered, you can help shed water down the side of wall with it. And for the water runoff, put a piece of flashing at the very bottom. It will take care of the rotting bottom, preventing water from seeping in from those cracks between the bottom and concrete.
fortunerestore is offline   Reply With Quote
Water system noise in house, help wanted lkustb Plumbing 3 09-01-2015 10:18 AM
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 07:42 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
