Hope I Did Not Screw Up- Argh! - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-29-2012, 09:06 AM   #1
Rewards Points: 155
Hope i did not screw up- Argh!
Doing my kitchen remodel- Wall cabinets in- base cabinets in- In doing so- all my base cabinets are sitting on the subfloor (which is very level)- They are screwed into the back wall studs and some have shims in front to get them level. I plan on installing floor after and just running the floor up to the cabinets. Now- I will run the floor under the fridge and stove - no big deal- If I run it under dishwaher - it will raise dishwasher about 5/16"- I have the dishwasher sitting in it's spot now (not hooked up)- In looking at it in the position it's in- I have about 1/2"-3/4" clearance above it to where the counter will go- I know I've read some people said they raised all their base cabinets to compensate- Do I really need to do that or would you thing i have enough cushion there to tile under the dishwasher and be able to get it out? My thought is that the dishwashers are never exactly as tall as the cabinets (or at least it looks that way)
Huskyfan68 is offline   Reply With Quote
Old 11-29-2012, 10:13 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 204
For your peace of mind why not put the flooring or something the same thickness under the dishwasher and see if it is too tall or not before you do anything else.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
drtbk4ever (11-29-2012)
Old 11-29-2012, 10:54 AM   #3
Rewards Points: 6,652
Take out the base cabinets, lay down som exterior grade plywood, equal to the height of the finished floor, that is cut to the dimensions of the cabinet width and length of where they will end at thw stove & fridge. That way everything will be cherry when you get done.
If you like, you can roll some Zinser or Kilz on the ply to seal and further protect it.
Old 11-29-2012, 11:03 AM   #4
Rewards Points: 2,516
Put the dishwasher on the subfloor. The dishwasher has adjustable legs and it will have a trim plate so you will never be able to see under the dishwasher that there is no tile.
hammerlane is offline   Reply With Quote
Old 11-29-2012, 11:07 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 204
Good idea but I have seen where the people did that and couldn't get the dishwasher out because the flooring was too tall and the dishwasher was sitting in a hole.
I like doing it like Greg explained to do it.
Jim
Old 11-29-2012, 11:12 AM   #6
Good point....Put the legs of the dishwasher on some scrap plywood secured to the subfloor. The thickness of the scrap plywood should be the same as the thickness of the tile/mortar/cement board.
The Following User Says Thank You to hammerlane For This Useful Post:
BigJim (11-29-2012)
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 09:30 AM
Nail Shear Strength Test ddawg16 Building & Construction 32 08-24-2012 10:17 PM
Help with Screw sizes needed! andyroo77 Building & Construction 5 06-02-2010 10:00 PM
Torque on a receptacle screw? Ultrarunner2017 Electrical 13 03-09-2009 04:35 PM
Ground screw in 4" box fw2007 Electrical 8 10-05-2007 04:07 PM
