Hooking Up Radiant Floor Heat - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-23-2009, 10:22 PM   #1
hooking up radiant floor heat
I want to put in electric radiant floor heat mat in my bath remodel under the tile. How do you connect it to the electricty w/o tearing up the walls to access the electric supply?
sagechickie is offline   Reply With Quote
Old 04-24-2009, 10:13 AM   #2
Rewards Points: 5,336
First you would have to determine the electric load the floor requires. I would recommend that the heating be put on it's own circuit, so in any case you would need to run a new line from the main panel to the bathroom. On the slim chance the instructions don't say that, you will still probably need to open some walls to get the wire where it needs to go.
Ron
Old 04-24-2009, 12:29 PM   #3
Thanks. well i was afraid that would be the case. we can do it, no problem, i just dislike doing drywall repair! oh well.
Old 04-24-2009, 01:46 PM   #4
The more you do, the better you get. Eventually you'll open walls like you open a door.
Ron
Old 04-24-2009, 01:53 PM   #5
Civil Engineer
Rewards Points: 4,764
I recently put radiant electric heat in my kitchen. The post regarding the new circuit is right on the money, you do not want to share the floor heat with anything else. You will also need a ground fault interrupt (GFI) for the circuit, you can either install a GFI circuit breaker, or in some cases (as in mine) the GFI is built into the thermostat that controls the floor heat. In any case, plan on opening up the wall both to run the new circuit and to install the thermostat.
Old 04-29-2009, 05:01 PM   #6
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
A low voltage system will not need a GFCI but will have a small transformer you'll need to place somewhere.
The best features about low voltage is that it comes with a 25 year element warranty, it can be cut and jumped up to the seat in a shower or the actual floor of the shower itself and then back out to the bathroom floor. In the worst case scenerio, if the element is ever damaged, it is easily repaired.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 04-29-2009, 09:56 PM   #7
Registered User
Rewards Points: 5,514
Is basement below? Or crawl? Then you only need thermo. hole on wall. Other heat source is required, if inspected. Be sure to use the nick alarm when installing over it. File the sharp corners of your thin set trowel rounded. Be safe, G
Old 04-30-2009, 05:44 PM   #8
i actually have 2 baths i want to add this floor heat to. The one is in a basement and would go over a concrete floor. the other is a main floor bath but the basement ceiling is finished. i'm looking at a bunch of wiring either way. I am intrigued by the low voltage heaters described by warmsme. I'll have to research this further. Anyone else have info on it?
Old 04-30-2009, 05:46 PM   #9
Rewards Points: 150
Search for a product called "FLOORIZWARM" low voltage radiant.
Old 04-30-2009, 09:32 PM   #10
thanks, i'll check it out!
Wanted: Second opinion on radiant floor/boiler hookup drh HVAC 4 01-16-2010 08:41 PM
using forced air for radiant heating djsmith9 HVAC 22 10-30-2008 09:50 AM
Radiant flooring question tpagel Flooring 7 05-21-2008 01:41 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 01:17 PM
radiant slab vs. overhead radiant tube holedpiston HVAC 2 05-09-2007 11:59 AM
