Hinged Shower Doors More Expensive Than Sliding Shower Doors? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 12:06 AM   #1
Rewards Points: 682
Hinged shower doors more expensive than sliding shower doors?
I've been told that hinge shower doors cost 3 to 4 times as much as a comparable sliding shower door, since they have to be custom made. Is this true? It seems likely, I can't imagine how one can adjust a premade hinged shower door.
darsunt is offline   Reply With Quote
Old 03-07-2012, 01:11 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Go ask the shower door people.
titanoman is offline   Reply With Quote
Old 03-07-2012, 06:53 AM   #3
Probably/possibly, as suggested, check prices. But all shower doors have to be tempered glass, so the holes have to be drilled before it is tempered, and MUST be dead on. So any mistakes get expensive.
Old 03-07-2012, 12:14 PM   #4
Disabled wood vet
titanoman's Avatar
I'm pretty sure I've seen them with self-stickum hinges.
You just hang the door with tape then peel the backing off the hinges and stick 'em on. Pretty easy.
They don't go on the surfaces, they go over the edges.
Old 03-07-2012, 12:21 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 480
The hinged doors are higher because they are thicker glass and are custom made to fit the opening.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 03-07-2012, 07:34 PM   #6
DIY staff
Rewards Points: 7,174
There are a few 'off the shelf' swinging doors available---not as nice as the customs but a lot cheaper than a custom---Look at a few shower door manufactures web sites--
If you have a standard width opening---You may be pleased with the stock items.
ben's plumbing (03-07-2012)
Old 03-07-2012, 07:44 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 480
What will they come up with next, I am a little behind times.
Jim
Old 03-07-2012, 08:05 PM   #8
Rewards Points: 582
yes some pre made doors will give to 1" of play on install...sterling, aquaglass,basco..
Old 03-07-2012, 08:11 PM   #9
DIY staff
Those doors are popular right now--so the manufacturers have stepped up with new items---
There are some dandy examples available---but only if you have a standard sized opening--(the direction to install them are worthless)
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (03-07-2012), BigJim (03-07-2012)
clawfoot tub shower enclosures too expensive lzimmer Plumbing 2 03-16-2011 04:15 PM
Sliding closet doors and baseboard olli Carpentry 1 07-29-2010 06:47 PM
Basco vs Coral Frameless Shower Doors janralix Plumbing 3 10-16-2009 10:34 AM
Bypass Shower Doors Install Question houston Kitchen & Bath Remodeling 4 01-31-2009 07:55 PM
installing a set of shower doors on my tub cherylj57 Appliances 2 10-10-2008 06:28 AM
