Help With Vault Project, Hip Roof - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 06:03 PM   #1
stingrayguy's Avatar
Help with Vault Project, Hip Roof
Hello! My name is Brad. I'm new to DIY Chatroom, but have been lurking for months.
My project is a first floor bath renovation.
House details,
built in early 1950's
1200 S.F. Ranch
Full Basement with steal beam.
Hip Roof.
2x10 rafters that run from front to back of the home.
Now my questions for you guys is. I plan to cut out the 2x8 rafters over my bathroom and raise my ceiling up to my roof framing. I plan to drywall the angle of my roof line.
My plan was to cut out the 2x8s that span over the bathroom, I wanted to cut them back 3 inches to place 2 2x12s and box off the area over the bathroom, I would then bolt the 2x12s to my existing 2x10 rafters. and ad a 2x12 flat over the 2x10 rafters to box them all in, while screwing and bolting everywhere I could. I will then frame out with 2x4s to my roof line that is built with 2x8s . The bathroom is 6x8, so I would be removing 6 parts of my existing 2x8 rafters.
Please tell me if you think any of this might work?
I have uploading pictures of my attic area, outside shot of the side of the house with the bathroom, a diagram of my home, and my plan to remove the rafters.
Thanks for your time!
Help with Vault Project, Hip Roof-img_4015.jpg   Help with Vault Project, Hip Roof-img_4022.jpg   Help with Vault Project, Hip Roof-img_4025.jpg   Help with Vault Project, Hip Roof-img_4020.jpg
stingrayguy is offline   Reply With Quote
Old 01-15-2012, 06:13 PM   #2
Framing Contractor
Rewards Points: 120
You are proposing something that is very ambitious. The loads must be calculated to determine if what you propose will actually work. Only a structural engineer can give you the answers you seek.
Please let us know how the project goes.
sixeightten is online now   Reply With Quote
Old 01-15-2012, 06:26 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I couldn't follow you.
But maybe...
Just cut the joists off flush.
Frame walls the rest of the way up, nailing the studs to the sides of the joists, and up to top plates that you have nailed to the rafters that you have put blocking in between for drywall backing and to nail your pony walls to.
Use 2x6 studs so you can get r-21 or whatever it is in your news walls.
Put R-30 in the rafters.
Put drywall nailers wherever needed.
(If you nail a 2x4 over the joists before cutting, they won't be bouncing around, popping drywall nails in the other rooms, and when you nail your studs alongside them).
(This is all if I understand what you are trying to do).
titanoman is offline   Reply With Quote
Old 01-15-2012, 06:46 PM   #4
Rewards Points: 13,750
It may be faster, cheaper less time to just build a new house with the roof lines for some reason you think you need then to go that route.
Your house will be next to impossible to live in this house while all this is going on.
Old 01-15-2012, 06:49 PM   #5
Disabled wood vet
titanoman's Avatar
What are you talking about?
Am I missing something? Isn't he just "vaulting" his bathroom up to the existing rafters? One day, another for sheetrock?
Old 01-15-2012, 07:50 PM   #6
I do have a call into a local structural engineer, I will let you know how that works out, I was just thinking that there shouldnt be much load on this small about of material I wanted to remove.
But maybe...
That would work, I only thought of the doubled 3x12 to box everything in and make it as strong as I could. I plan to use spray in insulation, I should be able to get around R-50
(If you nail a 2x4 over the joists before cutting, they won't be bouncing around, popping drywall nails in the other rooms, and when you nail your studs alongside them). Thats a good idea! Thanks!
Im only trying to bring the ceiling up to give the room some more space... Im installing 2 skylights, and I would rather not have to box the skylights out. more of a flush look I'm going for.
yes sir!
And... to explain a little more, The vault is going to start from my outside wall and angle up to the end of the room, witch will bring my ceiling up about 30". If you look at the 4th picture I uploaded of my roof 2x8s, that's where I plan to screw my drywall to. Simply going to drywall the roof line, with proper venting and insulation of course... follow me now?
Old 01-15-2012, 07:53 PM   #7
Disabled wood vet
titanoman's Avatar
yes sir!
Yeah. Pretty simple.
Old 01-16-2012, 09:16 PM   #8
And the project is a GO! I had a local structural engineer out today, I will have my drawings tomorrow and can continue working. I will update with photos tomorrow
Old 01-16-2012, 09:48 PM   #9
Disabled wood vet
titanoman's Avatar
I knew you could do it.
He probably just told you that you need to double up any rafters that you need to head out for the skylights and build the walls like I said?
Old 01-16-2012, 09:52 PM   #10
He told me a few things before he left.. Talking about building a knee wall in the center, around the joist's I remove, and to box in the cut area.. So I have to build a 8' long 36" tall wall.. and I will need 4 2x8s to double up the area.. I will have the drawing tomorrow.
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 09:25 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
