Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-03-2012, 01:39 PM   #1
Help trimming out half wall railing
Hey experts.. I'm having trouble trimming out my half wall railing leading downstairs. The part I'm having the most trouble with is the angle at the bottom of the wall where the 45* cut has to turn left 90*.. Pictures included. If anyone could suggest some angles for me to try.. or a different kind of trim to try.. that would be great!
Here is one -
Help trimming out half wall railing-img_3322.jpg   Help trimming out half wall railing-img_3324.jpg
casper129 is offline   Reply With Quote
Old 09-03-2012, 01:42 PM   #2
Pictures do not come up.
Old 09-03-2012, 01:46 PM   #3
Now both pictures should work...
Old 09-03-2012, 01:52 PM   #4
Going to have to make a compound cut on the long piece so the tip comes out even with the end of the wall.
Then cut tiny end piece for the cap on the end.
I'll see if I can find a picture of how to do it.
Old 09-03-2012, 01:56 PM   #5
Thanks a bunch. I have a 12" dual bevel slider, so the angles shouldn't be much of an issue... hopefully
Pictures would be really helpful... I'm just not picturing it in my head correctly yet....
Old 09-03-2012, 02:25 PM   #6
STAFF
BigJim's Avatar
While this isn't the same application or trim, the same principle will apply. Keith Mathewson, one of the finest stair builders I know wrote an article in THISisCarpentry.com with this illustration. You will need to cut a pie shape transition piece something in the same nature as the illustration below.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 09-03-2012, 02:26 PM   #7
So to make the turn I will have to use 3 pieces?
Old 09-03-2012, 02:31 PM   #8
Here is what I am looking for I think.. But it seems to me the part labeled "custom profiled return" is actually taller in height than the run of trim coming down the stairs....
Old 09-03-2012, 02:52 PM   #9
This:
I can't for the life of me figure out these angles..
Old 09-03-2012, 06:21 PM   #10
STAFF
BigJim's Avatar
You can do that but the custom profile trim will have to be hand made as it will be taller than the trim on the rake.
Jim
Old 09-03-2012, 06:24 PM   #11
It's more common to see cove moulding or 1/4 round used, not window casing for what your doing.
Old 09-03-2012, 06:33 PM   #12
we always used casing for half walls. shoe or quarter round would have fell in the gap above the drywall.
Old 09-03-2012, 08:05 PM   #13
Joe - That's what I was thinking.. but because of my lack of being able to cut straight, I was forced to use something larger. As DannyT said... 1/4 round wouldn't cover the gap in some areas. :/
Old 09-03-2012, 09:44 PM   #14
Alright guys, I think I figured out a solution. A little ghetto.. but it looks OK... I'll post up some pictures once I get it nailed up in a bit...
Old 09-04-2012, 12:58 AM   #15
Like I said.. a little ghetto fab.. But, it got the wife's stamp of approval, and that's all that matters in this house :D
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Need ideas for ugly half wall cynwil710 Remodeling 12 08-18-2011 02:34 PM
Does the bottom half of basement wall has to be insulated? Johnny Ren Building & Construction 29 12-16-2010 10:18 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
