#1 |
help sheathing my house correctly
Hi! We have started residing my house built in 1995 in the pacific NW. It had LP lap in the front, but T1-111 on the back and sides. We started pulling off the T1-111 and sheathing with OSB, but found that the framing of the house is such that the second level protrudes over the lower framing it seems to allow the T1-111 to overlap...
We are installing lap siding now... any suggestions for how to make the walls flush instead of having the overhangs? A second layer of OSB? Furring strips? Just stick a bandboard in between and keep on siding?? Thanks!! |
#2 |
Mod
Adding a BB is certainly the easiest and least expensive fix.
The problem with packing out the first floor is it creates issues with window revels, door jambs, etc. A BB also can be a nice trim detail if you use the right width, x6 is to narrow in most cases IMO. I usually use x8 or x10 and try to set it at a height to match up with any second floor decks if you have them.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#3 |
Custom Home Builder
If the second floor extends past the first floor and you put a bandboard there to break up the transition, then you need to put a 'Z' bend behind the second floor sheathing and across the top of the bandboard and then down (about 3/8" or so) over the face of the board to divert rainwater.
#4 |
Moderator
Did you know that T1-11 is structural sheathing? Needs no diagonal or let-in braces... To replace it with OSB (inferior to plywood T1-11) would be a waste of time and money. http://www.apawood.org/level_b.cfm?content=prd_sid_main
Ron mentioned added thickness already and TJM said Z-metal behind the sheathing---- I hope he meant behind the new building paper or housewrap, in front of the sheathing....... Unless you want a rainscreen below:http://www.greenhomebuilding.com/pdf/RainScreen.pdf Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Tags |
overlap, siding, t1-111 ![]() |
| Display Modes | |
| Weird wiring in house | fdmillion | Electrical | 13 | 06-14-2013 07:49 PM |
| Considering buying a house that needs regrading HELP | Dr.JUSC | Landscaping & Lawn Care | 9 | 06-16-2011 11:58 AM |
| Questions about jacking up house to replace rotted rim/sill | SolidStateS15 | Remodeling | 10 | 03-22-2010 12:43 PM |
| HVAC for c. 1956 House. What would YOU do? | David911 | HVAC | 10 | 02-08-2010 06:58 PM |
| Some walls rattle in my house if hit with something, I will explain inside posting | zincmann | Building & Construction | 4 | 11-10-2008 04:05 PM |
