Help With Really Odd Closet Doors! - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-04-2013, 11:11 AM   #1
Question
Help with really odd closet doors!
I'm out of ideas for my master bedroom closet doors. This is a long-term flip, we're hoping to sell in April of '14.
Each side opening is exactly 47 inches wide, so currently they're symetrical. The center partition cannot be removed (as far as I know) as it supports the half wall thing above it.
I thought about very narrow French doors, but I'd have to add casing on the far right side so the door will open and can be trimmed, since the current opening just ends on the wall.
I thought about bi-folds, but I don't know how I would add trim to that right side, or to the top of the opening to hide the tracks.
One big door on each side would be too big. Curtains... not good enough to resell I don't think, especially in the master bedroom.
I'm really really stuck. HELP!
bksullivan is offline   Reply With Quote
Old 11-04-2013, 11:22 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
Bifolds would be easiest next to sliders though you'd likely have to trim them a bit. The track can usually be hidden with quarter round or another profile depending on the height of the opening. Double swinging doors would have to be totally custom but still doable if you have the ability to build or the cash to buy.
iminaquagmire is offline   Reply With Quote
The Following User Says Thank You to iminaquagmire For This Useful Post:
bksullivan (11-04-2013)
Old 11-04-2013, 11:27 AM   #3
The height is about 72 inches. Quarter round might work, hadn't thought of that. I was concerned about adding trim to just the top without finishing the sides as well (which I'm not sure I can do thanks to Mr. Difficult Right Side), but a quarter round probably wouldn't look enough like actual trim to make it visually incomplete.
There were originally sliders in these openings, but with them you could only see about 21" of closet at a time, so they were SUCH an annoyance and hassle.
Old 11-04-2013, 12:25 PM   #4
K&B Designer
Live_Oak's Avatar
I'd reframe the whole thing so it actually made sense as a single closet rather than two separate closets. The vertical member in the center doesn't carry any real load of the decorative niche above, just the framing and drywall. Reframe it with a single header instead of two. Create the trim/mini-wall needed at the sides. Then use bifold doors.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
joecaption (11-04-2013)
Old 11-04-2013, 12:31 PM   #5
Rewards Points: 338
What I meant with the quarter round was only to hide the track for the bifold doors, which are usually set back in the opening a little bit. You have drywall wrapped jambs which don't usually get casing. Also, with a 72" height, any store bought door won't fit without trimming a lot off the top and/or bottom.
As for removing the divider, it looks like it is the full width all the way to the back wall. While I've seen some stupid walls built, I'd be concerned that it hid some kind of ductwork or structure.
Old 11-04-2013, 02:08 PM   #6
Rewards Points: 12,856
I agree with the idea of reframing the opening.
Old 11-04-2013, 06:18 PM   #7
Rewards Points: 6,652
Another vote for reframing. Frame it with 2x6 for the header at the front, and 2x4 for the top, with maybe 1/2" plywood, and then use 1/2" or 5/8" Drywall on top of that. It should then be able to hold any kind of weight placed on top.
Tags
closet , closet doors , framing , remodel , trim
Custom make closet doors midmo Windows and Doors 1 07-28-2011 03:27 PM
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 03:20 PM
Bifold Laundry Closet Doors? DIYtestdummy Remodeling 2 02-14-2008 03:38 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
Mirrored closet doors VVAVALE Painting 2 08-19-2006 07:34 PM
