Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-18-2011, 10:35 AM   #1
FordRacer2007's Avatar
Send a message via AIM to FordRacer2007
Help with pole
I have this cement filled pole in my garage that was put there to prevent a car from hitting the tank. It is however preventing my girlfriend from parking closer to the wall and now that I have a wider car, we can't get out of them when they are both in the garage.
Does anyone know what I need to use to remove it? Also, any ideas of what else I can use to protect the tank? I was thinking of boxing it in.
FordRacer2007 is offline   Reply With Quote
Old 06-18-2011, 01:40 PM   #2
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
Help with pole
I would take a sawzall with a metal blade and cut around the perimeter of the pipe then grab hold of the pipe and break it off the concrete. Then I would invest in a tankless hot water heater and then you wouldn't have to worry about protecting the tank because the tankless would be hanging on the wall.
danrb007 is offline   Reply With Quote
Old 06-18-2011, 01:42 PM   #3
Help with pole
Thank you, but right now I can't invest in a tankless water heater. Won't breaking it damage my concrete floor?
Old 06-18-2011, 01:45 PM   #4
Jack of all trades
danrb007's Avatar
Help with pole
It shouldn't your garage floor is a lot thicker than the diameter of the pipe.
Old 06-18-2011, 01:47 PM   #5
Help with pole
I've never done anything like that but I'm guessing that will leave something behind that I will have to smooth out right?
Old 06-18-2011, 02:16 PM   #6
Tileguy
Bud Cline's Avatar
Help with pole
007 has a good solution:
Sawzall blades are flexible and you can cut the pipe by allowing the blade to skim the floor surface. You will however mark the floor permanently. Once the steel is cut all around the concrete inside will break off at the floor level or pretty close to it. You will still have the steel ring remaining but that shouldn't be a big deal. If the floor surface then has a pock in the concrete inside the pipe after the pipe is remove that little bit of damage is easy enough to fix. If you cut the pipe exactly at the floor surface there shouldn't be anything to fix except a little missing concrete inside the pipe.
Old 06-18-2011, 02:18 PM   #7
Help with pole
Alright, thanks for all the help .
Old 06-18-2011, 02:56 PM   #8
Tileguy
Bud Cline's Avatar
Help with pole
Good Luck!
You will need several saw blades. Pricy little devils.
Old 06-19-2011, 10:34 PM   #9
Moderator
Help with pole
You may want to re-think just boxing it in. Check with your local Building Department before taking on the insurance liability of removing the required by fire-code safety bollard, pp.6; http://www.codecheck.com/cc/images/CC5thEdSample.pdf
I doubt your H.O.I. policy will cover any claims from damage/fire/explosion if hit with a vehicle.....
Gary
Clothes taking longer to dry?
Old 06-19-2011, 11:23 PM   #10
Missouri Bound's Avatar
Help with pole
One more thing....I would never buy a tankless water heater....over rated and not energy wise in most situations.
Old 06-19-2011, 11:32 PM   #11
Tileguy
Bud Cline's Avatar
Help with pole
Check with your local Building Department before taking on the insurance liability of removing the required by fire-code safety bollard.
Never gave a thought to the thing being required by code or insurance. Good point.
The Following User Says Thank You to Bud Cline For This Useful Post:
Gary in WA (06-22-2011)
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 09:12 AM
Double pole breaker used as single pole WonderingOne Electrical 11 11-30-2010 01:37 AM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 01:44 PM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
