Help With Lighting Please.... - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 09:19 PM   #1
Rewards Points: 77
help with lighting please....
I will be remodelling my kitchen/living room area..(open floor plan). The room is 26'L x 18'W. I also have a sloped ceiling. It is 8' at one end and 11' at the other. I am wanting to put in recessed pot lights. What size lighting should i put in? I think about 18 lights would be needed but i am not sure what size to put in? 4,5 or 6 inch? How do i get the light to point downwards if the ceiling is sloped? Any ideas or help, thanks!
bcbud3 is offline   Reply With Quote
Old 10-20-2010, 11:15 AM   #2
Rewards Points: 5,336
They have special cans made for sloped ceilings. Check the box to see if they will work in your particular slope as they are limited in range.
Decide first how much light you will need. Then,based on that decide on the can width. The larger the can, the bigger the bulb you can use. Generally the 4" can is limited to about 50 watts. Even the 6" cans have been reduced in wattage. You used to be able to put in 150 watts. Now the limit is more like 95. You can use florescents, but many are not dimmable.
Ron
Old 10-20-2010, 08:42 PM   #3
Rewards Points: 77
i looked and the price of the sloped ceiling cans and trim is just way too much. I will buy the normal box and the eyeball trims. The manufacturer doesn't have the gimbal trim in the size that i am looking for.
Old 10-20-2010, 09:30 PM   #4
Using the eyeball trims will reduce the wattage you can use in the can. Take that into consideration when you plan the number of cans used.
Ron
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 03:20 PM
Basement Lighting blaze01 Electrical 1 02-16-2010 12:24 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
