Help With Lighting Basement - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-12-2012, 11:03 AM   #1
Rewards Points: 202
Help with Lighting Basement
Hi all. I am working on slowly remodeling my basement. First thing is to get some decent lighting down there so I can see what I am doing.
I have decided on recessed lighting and I would like to do LED if I can find some options at affordable prices.
My question is, I am at a loss for how to arrange the cans given the room layout. Below is a picture. I definitely want to add a light at the bottom of the stairs (as shown in the picture), which will be on a separate three-way switch at the top of the stairs and at the bottom. There is also a light at the top of the stairs which illuminates my house's side-door entrance.
Otherwise, I can't figure out the best way to arrange the lighting. I know I want all lights on dimmers, perhaps three-four on each dimmer. The soffit down the middle will likely block out much of the light from the other side of the room, so I think it best to treat as two separate areas.
Any tips or ideas.
Thanks!
benleef is offline   Reply With Quote
Old 12-12-2012, 11:22 AM   #2
Rewards Points: 672
I would say 2 at minimum and 3 at maximum recessed lights centered on each side of the soffit spaced evenly along the 15'.
You have on the drawing that the walls on the right side next to the stairs will eventually be removed. What will be behind it? Will that need to have a recessed light also? Plan ahead.
LED are so expensive. I just ended up getting the basic Halo at HD and using a BR30 (?) bulbs for my basement
B
Beepster is offline   Reply With Quote
Old 12-12-2012, 11:37 AM   #3
Rewards Points: 202
Thanks!
Do you think Three (centered) in addition to the light at the bottom of the stairs would be OK?
The walls are basically just splitting the basement in half. The other side consists of a a bathroom, laundry area and boiler area. The room in the picture will likely open up a bit, but not too much. You make a good point of planning ahead. Perhaps I can space the lights so that if I needed to add one more in the opened up area it would line up correctly.
Old 12-12-2012, 05:02 PM   #4
Because of only a 6'6" ceiling height you really need to be worried about bulb heat and size. LEDs are really going to be your best bet although the most expensive. I would use 4 to 6 4" cans with LED bulbs. If it were me at least. However if it were me and the cost was an issue I would use 3 recessed fluorescent 4' T8s.
rebelranger is offline   Reply With Quote
Old 12-12-2012, 05:29 PM   #5
Rewards Points: 6,652
15x15, just hang some dual bulb fluorescent fixtures if not finished. Six 48" T-12 two bulb should work fine down there.
Old 12-12-2012, 05:36 PM   #6
Rewards Points: 202
There are some florescent fixtures down there already. They don't provide enough light, they take forever to turn on, they are not dimmable, and the plan is to finish the basement. Why not spend the money on what I'm going to use in the finished space?
Old 12-12-2012, 07:04 PM   #7
Depends on what kind of ballasts are in them. How high from floor to ceiling are we talking at the lowest & highest spots?
Old 12-12-2012, 07:21 PM   #8
Rewards Points: 202
It's about 6.5 at highest and 6 at lowest.
Old 12-12-2012, 07:47 PM   #9
You are not going to be able to finish that basement. Too low for headroom. Not even good for anything unless you are 4 foot or 5'-4". Best would be to go with the fluorescent T-12 48" fixtures mounted up in the joist bays.
Old 12-12-2012, 07:55 PM   #10
Rewards Points: 202
The headroom is not going to keep me from finishing the space for nice bright clean storage and extra TV area. It obviously won't be a living space but something better than cold concrete and dusty and dingy space.
Old 12-12-2012, 08:05 PM   #11
Even for putting a tv down there, you cannot finish it, due to your local permit office will never let it fly. After you figure floor, ceiling, you are going to loose a lot more headroom. Best to just use for storage.
Old 12-12-2012, 08:21 PM   #12
Rewards Points: 202
I'm obviously not going to have my living room down there, but I don't see the issue putting up drywall and a floor. I'm not going to be getting a permit to do it. Even if I were, there are people with legalized finished basements with the same houses as I have. It obviously isn't considered "habitable" space, but its square footage that can be utilized.
Old 12-12-2012, 08:59 PM   #13
It is because your local permit office will never allow it. Unless you are placing the drywall on the ceiling for fireproofing, and sealing the main living area from the cold zone, being the basement, that would be the only way you could get away with it.
It is just not feasible for being able to finish it and use it as a place to hang out, let alone get decent lighting at that low of height.
Old 12-12-2012, 09:10 PM   #14
Rewards Points: 202
Not getting a permit. Not sure how you know what they'll allow but thanks for your help I get that it's not best place to invest in work. I'd still like to see down there. Ill look into fluorescents
Old 12-12-2012, 09:25 PM   #15
Because you are wanting to finish it. That means that you are wanting to use it as a living space. That means when your local city finds out, you will not get permits to finish as a living space. Good luck on this, but personally the head room is the part that I cannot get past as the kicker, why not to use it for hanging out, due to all you are going to do is stand up stooping over all of the time, unless you are under 5'-4".
Recessed lighting in basement - thoughts on layout sheffdave2002 Remodeling 15 11-20-2012 09:49 PM
Installing basement recessed lighting jdtox Electrical 13 05-06-2012 09:44 AM
Lighting in Basement nhoj Electrical 14 02-25-2012 03:51 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
