Help With Insulation - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 09:32 AM   #1
Help with insulation
We are building a kitchen on the porch, you know taking down walls making bigger kitchen. I need to know if I put plastic in the inside of the wall that is a outside wall, also do I do this on the outside the wall that we have to put siding on? Thanks
duphus is offline   Reply With Quote
Old 01-30-2012, 03:37 PM   #2
Nope. You'll end up trapping moisture in the double barrier. All the new data points to a vapor barrier on the warm side of a wall (the interior) only.
Just use tyvec or felt (tar paper) on the exterior, they are both water resistant but allow vapor to pass. So after installing your sheathing, staple or button cap your tyvec or tar paper. If water gets in the wall, you need this breath-ability to prevent mold.
Use minimum 6mil wrap on the interior (between studs and drywall) and use seaming tape any seams or breaks. Staple it up and you're good to go. This goes for the ceiling as well (assuming there will be unconditioned space above).
RenoStruct is offline   Reply With Quote
Old 01-30-2012, 07:00 PM   #3
help with insulation
Thanks alot RenoStuct
Old 01-30-2012, 07:53 PM   #4
Registered User
Rewards Points: 5,216
Where are you located?
The vapor barrier goes on the warm side as said---- if in a cooling climate, to the outside;
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
RenoStruct (01-31-2012)
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 06:44 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
