Help With Installing Kitchen Cabinets. - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 07:09 PM   #1
Help with installing kitchen cabinets.
This is my first post in the forum so I would like to thank anyone in advance for any advice. I just had custom kitchen cabinets installed under soffets. I want (have) to do crown molding. My delima is that the front of the cabinets are flush with the front of the soffets.
If I install crown molding at the top of the cabinets the crown molding will be levitating on the top. What should I use between the cabinets and soffets? Thank you in advance.
rsoby2112 is offline   Reply With Quote
Old 10-03-2009, 09:19 PM   #2
Custom Cabinet Maker
make a matching Plate shelf above the cabinets, pocket screw or make a small ledger strip under it screw thru that, cover all the with the crown and it will look like it was meant to be there
skymaster is offline   Reply With Quote
Installing Cabinets In Un-level Kitchen whiskeykid Carpentry 14 01-31-2009 08:43 AM
Installing receptacles in kitchen base cabinets shtoink Electrical 13 10-15-2008 08:52 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
Installing Kitchen cabinets help helpless handyman Carpentry 16 07-07-2007 07:12 AM
installing kitchen cabinets ncoppola09 Carpentry 9 01-06-2007 10:07 PM
