Help With Cutting A Hole - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-24-2012, 10:53 AM   #1
Help with cutting a hole
Hello I'm trying to fix up a wall for my mother-in-law and I could use some advice on how to cut a hole in laminate floor. She wants to extend the wall that is there but about 12", I wouldn't think screwing the new 2X4 to the floor would be a good answer but maybe it is. I was thinking that I would have to remove some of the flooring where the 2x4 is going to be but not sure how to cut the flooring.
I was thinking a skill saw would do that job but I might not have the room to use one. Any ideas or suggestions would be great and thanks in advance for any the choose to help me with this.
PS. I have lost my mind, if you see it can you send it back; I miss it
Stephen68 is offline   Reply With Quote
Old 03-24-2012, 11:03 AM   #2
Rewards Points: 13,690
A picture of where this 2 X 4 has to go would be big help. Just cut the 2 X 4 and lay it right on the floor when you take the picture.
If your doing what I think your doing I'd lay the 2 X 4 on the floor, set a scrap piece of 1/2" thick baseboard along the side of it and mark it with a sharp pencil. Then just use an ossilating saw to make the cuts. It can plunge straight down, and make 90 deg. angles.
I use the 1/2 baseboard because most laminet floors call for 1/2 clearence to the bottom plates.
Old 03-24-2012, 11:46 AM   #3
Yip that is the tool I need, don't know why I never thought of it. Now I hope I know somebody with one because I'm pretty sure I don't have one . Thanks for you time and help
Cheers!
Stephen
Old 03-24-2012, 12:09 PM   #4
That's one tool well worth buying if you do not have one.
I own 3, two Rockwell Multi Crafters and one cheap Dremal brand which is just a toy and not worth buying, it's the one I lend out.
Old 03-24-2012, 12:14 PM   #5
DIY staff
Rewards Points: 7,174
I've got Harbor Freights best and it works very well.
Old 03-24-2012, 12:28 PM   #6
Far less expencive to.
Tags
cutting laminate flooring
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
Cutting a hole for an electrical box eagertolearn Drywall & Plaster 15 07-24-2010 01:36 PM
Plaster wall - cutting out an access hole, but how to replace it? Steelmesh Building & Construction 8 11-07-2008 09:40 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 08:08 AM
