HElp: Can I Install An Oven And Microwave In This Location? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 02:43 PM   #1
HElp: can I install an oven and microwave in this location?
Hi everyone
Can I install an oven below and a microwave above? If yes, what is the most cost effective way to do this? I am a COMPLETE NOVICE when it comes to home improvement so any and all help/insight is greatly appreciated!
Notes: there is a gas hookup under the stovetop in the back of the cabinet space. There is also an outlet right next to it. The vent above leads outside
MountainClimber is offline   Reply With Quote
Old 02-22-2013, 02:53 PM   #2
What oven dimensions should I be seeking?
Old 02-22-2013, 02:59 PM   #3
justinramani's Avatar
Why wouldn't you be able to? Simply get 36 inch appliances, retrofit the bottom cabinets to allow for a stove and ensure that the surface of the stove isn't much higher the 27 inches that you have.
justinramani is offline   Reply With Quote
Old 02-22-2013, 03:31 PM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Most ranges (stoves) are 30", but there are 36" units available. Just nowhere near as many. Are you planning on putting in new countertops? There is a good chance that you aren't gong to be able to remove that tile to a nice, straight edge. In addition to gas, you will also need an electric outlet to plug the new range into, which you have. The microwave will probably use a normal plug, so if your exhaust fan is hard-wired, you may need to install an outlet. Most of the time an outlet is installed in the cabinet above the microwave, with a hole in the bottom of the cabinet.
The hardest part is going to be that base cabinet. If it was one single unit, like is common for sink bases, you're pretty-much sunk without replacing or rebuilding that cabinet. If it is 2 separate "skinny" cabinets on either side of the main part, just remove that center one and you're on your way. They look to be a pretty-standard oak cabinet, so if you have to replace that whole cabinet unit with 2 skinny cabinets, it shouldn't be too hard to find.
hyunelan2 is offline   Reply With Quote
Old 02-22-2013, 03:33 PM   #5
Rewards Points: 13,230
Anything can be done if you have the time and money.
That countertop would have to be demoed, your going to need a shorter cabinet over the stove most likly.
You need 18" of clearance from the stove to the bottom of the microwave.
Old 02-22-2013, 04:17 PM   #6
There's 17" of clearance. Will that suffice?
Wall oven microwave combo patrick584 Electrical 6 09-02-2012 11:25 PM
Microwave oven recess jfair Carpentry 8 07-21-2012 08:23 AM
split 220V 3wire between Oven and Microwave Abhi Electrical 2 01-17-2011 09:50 PM
Oven Install and Replacement- Dacor $400 CostcoMan Appliances 1 05-24-2010 07:02 AM
wall microwave oven combo install Jaymross@mac.com Carpentry 3 10-08-2008 06:00 PM
