Help!!! Blow-in Insulation Bowing Drywall - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-09-2007, 03:04 AM   #1
Help!!! Blow-in insulation bowing drywall
We just replaced a damaged lath and plaster wall with sheetrock. The inspector now informs us that we need to blow in insulation, before he will sign off. The problem we are having now is, the screws are pulling through the drywall as we fill the cavity. It gets about 2/3 full then "POP", and the screw heads disappear. We used dimplers to set the screws, so I don't think they're too deep. We've tried adjusting the flow on the machine, but it doesn't seem to make any difference. What else might we be doing wrong?
Thanks in advance!
Erebus
Erebus is offline   Reply With Quote
Old 08-09-2007, 10:07 AM   #2
sounds like air pressure causing the screw to pop... do you have vapour barrier (plastic sheet) under the sheet rock, if you do, this probably cause air unable to escape while you blowing, although I never done this... but in terms of physics, you kind of need to have a window open up to let air escape to avoid the pressure....
may be easier just uninstall the drywall and put in regular insulation and then reinstall the drywall....
KUIPORNG is offline   Reply With Quote
Old 08-09-2007, 07:20 PM   #3
General Contractor
joasis's Avatar
Without seeing it in person, it would only be a guess, but the above advice is on the money, take the drywall down, and have the walls wet blown and scrubbed....with cellulose, this is the most effective insulation you will achieve.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 10:27 AM
Wet Insulation and Drywall jr66 Building & Construction 6 05-06-2007 09:56 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
