Help---(bath Tub) - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 08:47 AM   #1
Help---(bath tub)
We have a bathroom that is between the kitchen wall of cabniets and the outside walls and the bathroom is 5' wide and 8 feet long how do I get a new tub in and how do I get the old one out. please some one help it is a tight sqeeze.
Snickers123 is offline   Reply With Quote
Old 12-23-2012, 09:53 AM   #2
Rewards Points: 13,300
What's the old tub made of?
How wide is the door opening?
Old 12-23-2012, 09:57 AM   #3
DIY staff
Rewards Points: 7,174
After you remove some drywall the tub will tilt the hole using the open stud bay----tubs are usually 14 to 17 inched tall and will go through and common door opening.
Most tubs can be remove whole after the drain and overflow have been removed---
Some times cracking a cast iron tub with a sledge hammer is the easiest way----
mae-ling (12-23-2012)
Old 12-23-2012, 10:51 AM   #4
the old tub is cast iron and the door opening is 24 in but we can make is 30in and this is the tub we bought but i think we nee to get a simplier one
http://www.homedepot.ca/product/mona...-tub-rh/975167
Old 12-23-2012, 11:14 AM   #5
DIY staff
That is 25 inches deep---that should be able to wiggle into the room through the 24 inch door---
door framing is 26 inches---removing the door frame might be needed, but I doubt it---
Old 12-23-2012, 11:35 AM   #6
funfool's Avatar
Rewards Points: 534
I hate busting up a cast iron tub with a sledge hammer. Be sure to wear ear plugs.
Is sometimes the best way to remove the old tub.l
funfool is offline   Reply With Quote
Inline Bath Vent Switch Wiring Dano81 Electrical 3 05-09-2012 11:52 PM
Relacing a shower with a half bath seth Building & Construction 9 11-22-2011 11:58 AM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 10:31 AM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
