-   -   Help---(bath tub) (http://www.diychatroom.com/f15/help-bath-tub-167175/)
Snickers123 12-23-2012 07:47 AM
Help---(bath tub)
We have a bathroom that is between the kitchen wall of cabniets and the outside walls and the bathroom is 5' wide and 8 feet long how do I get a new tub in and how do I get the old one out. please some one help it is a tight sqeeze.
joecaption 12-23-2012 08:53 AM
What's the old tub made of?
How wide is the door opening?
oh'mike 12-23-2012 08:57 AM
After you remove some drywall the tub will tilt the hole using the open stud bay----tubs are usually 14 to 17 inched tall and will go through and common door opening.
Most tubs can be remove whole after the drain and overflow have been removed---
Some times cracking a cast iron tub with a sledge hammer is the easiest way----
Snickers123 12-23-2012 09:51 AM
the old tub is cast iron and the door opening is 24 in but we can make is 30in and this is the tub we bought but i think we nee to get a simplier one
http://www.homedepot.ca/product/mona...-tub-rh/975167
oh'mike 12-23-2012 10:14 AM
That is 25 inches deep---that should be able to wiggle into the room through the 24 inch door---
door framing is 26 inches---removing the door frame might be needed, but I doubt it---
funfool 12-23-2012 10:35 AM
I hate busting up a cast iron tub with a sledge hammer. Be sure to wear ear plugs.
Is sometimes the best way to remove the old tub.l
