Help Basement Step Layout! Please! - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 10:51 PM   #1
Help basement step layout! Please!
I am remodeling my basement and my steps are super steep. This problem is holding my remodel up now.I live in a modular home on a basement. The problem is when you get almost to the bottom of the steps you run into the floor joists then you go down a step and run into the metal frame. I have attached a quick drawling with all my measurements so maybe some one can help me out with length,step height so i can avoid hitting both beams. I have plent of room for overall length. I already had a contractor look at them and tell me im pretty much stuck. Please Help!!! Thanks.
fastmike22 is offline   Reply With Quote
Old 02-12-2012, 10:55 PM   #2
Rewards Points: 14,026
Relocating the stairs may be your only option. Some place you could install them at a right angle to the way they are now may work.
Old 02-12-2012, 11:08 PM   #3
I really cant move them. I have no other place to relocate them. Im pretty much stuck with what i have. Just trying to find my best option for measurements..
Old 02-12-2012, 11:12 PM   #4
What is the run length as well as tread depth and riser height?
Fantastic is offline   Reply With Quote
Old 02-12-2012, 11:27 PM   #5
http://www.blocklayer.com/stairs/stairseng.aspx
Old 02-13-2012, 12:11 AM   #6
Right now my total run is 88" My tread is 7 1/4 and my rise is 8". I am using 2x12 for my steps
Old 02-13-2012, 09:57 AM   #7
Originally Posted by joecaption
I second this post!
basement layout help twobirds Building & Construction 3 01-15-2011 03:23 PM
Finished Basement Help! twobirds Remodeling 0 01-15-2011 02:11 PM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
layout, basement redo yellow.shoes Remodeling 1 10-20-2004 08:04 AM
