HELP With 1" Stainless Steel Tile, Can't Cut! - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-12-2008, 02:20 PM   #1
Rewards Points: 44
HELP with 1" stainless steel tile, can't cut!
The guy doing our backsplash is having a hard time cutting the 1" stainless steel tiles on a backing mesh. Number one because the metal is a you-know-what to cut, but more importantly because the steel layer is actually crimped around an underlying porcelain tile (not glued), so it pops off when you cut it.
Any ideas? He's using a diamond blade, a wet saw ... the pieces go flying everywhere under the blade. Any tips greatly appreciated!
blakekr is offline   Reply With Quote
Old 05-13-2008, 10:20 PM   #2
Boz
Gus
Boz's Avatar
Try a grinder with a "metal cutting" wheel. Lay the piece your cutting on a piece of soft rubber, styrofoam, or something similar to reduce vibration.
Boz is offline   Reply With Quote
help me find a stainless steel toilet bowl and ... amakarevic Plumbing 2 01-30-2008 03:37 PM
cleaning stainless steel appliances? Yeti Appliances 3 12-11-2007 10:30 AM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 08:09 PM
Gauge of stainless steel sink Not Sure Plumbing 2 08-29-2006 05:56 AM
stainless steel kitchen sink KANUTTER Plumbing 6 01-09-2006 04:42 AM
