Hello All! I Need Help On How To Remove An Old Standup Shower - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 06:44 AM   #16
Originally Posted by oh'mike View Post
Does the base look like plastic or fiberglass? or is it solid like concrete(Terrazzo)?
The base of the tub?
6ft3soldier is offline   Reply With Quote
Old 06-20-2010, 06:47 AM   #17
DIY staff
Rewards Points: 7,174
Yea,I need to know if you need a big hammer to crush the concrete base before you saws all the remaining drain parts out ---or a skill saw to cut up the fiberglass pan.
Old 06-20-2010, 10:24 AM   #18
I will need to do that just to remove it?
Old 06-20-2010, 01:46 PM   #19
kwikfishron's Avatar
Rewards Points: 576
He needs to know if the base of the shower is basically (Concrete or Plastic).
Then he can tell you the method of removal.
kwikfishron is online now   Reply With Quote
Old 06-20-2010, 03:32 PM   #20
DIY staff
Most shower drains are not designed to be removed---On The older ones the pan is sealed to the pipe with okum and molten lead--
The newer ones use a rubber dough nut-- hammered in between the pan and the pipe.
If you wanted to save the pan I suppose a person could work for a few hours and pick the seal out--
But to scrap the old thing it's easier to quickly destroy the pan --then SawsAll the remaining parts off the pipe.
I could have had that thing in the dumpster in less time than all of this typing has taken!!!!
---Mike----
Old 06-20-2010, 03:36 PM   #21
Rewards Points: 276
Sometimes those drain nuts rust on so you can't get them off. I wonder if that's what he is trying to do. I wish I'd known years ago that I could just cut one fo those down the middle with a metal sawzall blade. We made do without a shower for a long time before I decided to just demo the whole thing and replace it.
Jim F is offline   Reply With Quote
Old 06-21-2010, 09:32 AM   #22
The base of the shower is plastic not concrete.
Shower caulking donjt81 Kitchen & Bath Remodeling 5 11-20-2009 01:41 PM
advice on shower system djrussell Plumbing 3 07-13-2009 10:39 AM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 02:30 PM
Plumbing in the shower head obeans Plumbing 3 03-11-2009 03:08 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 01:02 PM
