Heavy Natural Stone Wall Tile: Mastic Or Thinset? Is Drywall Adequate? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 05:53 PM   #1
Heavy natural stone wall tile: mastic or thinset? Is drywall adequate?
Friend wants help putting up a very heavy (about 5 lbs/sheet) natural stone facade over two tall 12" square columns. The stone will be stacked about 7' high. I'm confident the columns are sturdy, 2x4 construction, feel solid when i put pressure on them from various angles and they are drywalled- 5/8". The store the stone was bought from told her: 1) drywall is fine, no cement board required; and 2) use thinset, not mastic. The columns will not be in a wet or damp location (and they are interior). The stone is the thick (maybe 1"), glued-together kind... No mesh on the back, but some natural porosity to the stone. No grout is used with this kind of stacked stone.
My questions:
1) Why thinset? Will it grip tightly enough to this heavy stone facade? The weight will be much greater than the tile I've normally worked with in my own home. Is mastic better suited for this? I've reviewed the message boards, I know there is some definite hostility towards mastic overall ;-) but I'm honestly worried that thinset would be brittle.. Wouldn't mastic provide a tiny bit of flexibility?
2) Is drywall really sufficient for this? The drywall, too, is sturdily attached, but the weight of this stone makes me nervous.
3) How high can I build the stone up before needing to let the [mastic or thinset] dry?
I really appreciate the help.
Minich is offline   Reply With Quote
Old 01-31-2012, 08:43 AM   #2
Rewards Points: 3,130
I'm not a stonemason, just a DIYer, but I've researched this some and here's what I would do:
Wrap the columns with roofing paper (not normally required indoors but you want to protect the drywall from moisture). Then wrap them with expanded metal lath attached with plenty of galvanized nails. Apply a 1/2-inch scratch coat of mortar (Type N or S, not thinset) and let dry 48 hours. To apply the stone, completely butter the back of each one with mortar (about 1/2-inch) and press it in place with sort've a wiggling motion, enough so that some mortar oozes out around the edges. Hold in place for a few seconds. Repeat until done.
Old 01-31-2012, 08:57 AM   #3
That's not what I expected. ;-) So, you create your own cement board in place, kind of.. Neat. Where'd you find this?
Old 01-31-2012, 10:15 AM   #4
Somewhere on the internet. I also talked to the mason who built my chimney, which will eventually be faced with veneer.
If there's a Home Depot near you, ask them for their brochure on manufactured stone veneer. There's a good description in it of how to install the stuff. Process is essentially the same for the real thing.
One thing I never knew was why the mortar you put over the lath is called a "scratch coat." The HD brochure shows a picture of what it means.
Old 01-31-2012, 08:28 PM   #5
Thanks. Now that you've given me some of the terminology I've been able to do better research in the web, myself. It looks like a pain in the ass. :-) I'll let her know it's a weekend "plus some" kind of job! I should have known better than to promise help before I knew everything it would entail!
Old 01-31-2012, 10:33 PM   #6
Rewards Points: 490
I agree with the lathe and scratch coat but suggest that plywood be used as the backer board, not cement board, not sheet rock. The nails work better too. Mortar mix or make your own with sand and portland cement. No mastic, no thinset.
diyorpay is offline   Reply With Quote
Old 01-31-2012, 10:57 PM   #7
I see. If using plywood, would I skip the roofing paper? Seems like I would but I'm still learning about this-
Old 02-01-2012, 05:51 AM   #8
Rewards Points: 490
I would skip roofing paper since it's an indoor location.
Old 02-01-2012, 09:27 AM   #9
Check out www.themoldstore.info/installing_stone.html. It's a DIY guide for installing stone veneer. One thing that's sort've counterintuitive is, you should start at the top, not the bottom.
Full wall of tile over drywall eend Drywall & Plaster 1 07-24-2011 06:30 AM
Prep Concrete Block Wall for Natural Stone Veneer SCPete Building & Construction 2 03-06-2011 12:19 PM
replacing wall tile on uneven surface johnpaul8379 Kitchen & Bath Remodeling 2 02-22-2011 04:26 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 10:39 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
