Heavy All Glass - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 10:07 PM   #1
Heavy All Glass
Were trying to get an idea of what a heavy all glass shower would cost us. We currently have the normal sliding glass enclosure.
valpd is offline   Reply With Quote
Old 05-30-2013, 05:07 AM   #2
DIY staff
Rewards Points: 7,174
If you are talking about shower doors and walls---make some local calls. I expect to pay $2000 to $3500.
Old 06-02-2013, 08:07 AM   #3
Could I substitute the sliding glass door with the thick glass door without changing anything inside the shower?
Old 06-02-2013, 08:21 AM   #4
DIY staff
If the wall is drilled for the existing door--you might have problems hiding that damage with the new doors.
Also--the swinging doors are heavy----there must be solid framing where the door will be attached----good bath remodelers will have dine that when preparing the wall for tile---however, not all remodelers think of proper framing--so don't count on it----call in a glass company and have them check and see if the shower is suitable for the type of doors you want.
Old 06-02-2013, 10:39 AM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,562
Mike's point is very important.... I regularily redo showers in upgrades on property and quite often reframe to hang that door.
As far as a cost consideration, the size of your door will be an important factor, which you may want to consider/ address if you do reframe anything. Not so much absoulute sze, more of an issue of a standard size.
I've had excellent luck with ordering off the internet, and often a vendor seems to have some overstock sizes. Paid $400 last time (including shipping) for 30" door, 1/2 glass, and excellent brushed nikel hinges/pull. Sorry, the vendor records are buried deep in a house file.(EDIT: Incidentally, HD was $1200 for virtually the same door.)
Also, we had a surround put in at my sons, not too custom, but two panels cut to specific size. We got quotes from $1300 to $4600. There was some nominal quality considerations involved,..... but the point being is that you may find a large bid range, and shopping it may be well advised.
Best...
Peter
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
oh'mike (06-02-2013)
Old 04-10-2014, 05:12 PM   #6
Originally Posted by Steven James View Post
There's no standard glass sized for frameless systems. There are so many variables. Price is depend on Glass texture, glass thickness, color, hardware, where your location, and a number of other factors. We just bought ours from a local glass company and had them install as well: 1 side, 66" long. 30" x 84" door and a 30" wide fixed panel that sits on top of a 42" high knee wall, so the fixed glass is 42" tall and, 3/8" glass. Total: $1650 installed. For price comparison, we are in the Midwest.
Steve.... This is a year old.... but just as discussion.... yes there is no standard size for a cistom enclosure, however there are standard sizes for shower doors.... which you can easily frame the door to if you are redoing a shower.
And some of the semi frameless systems, come in standard sizes that you just build your curbs, or knee walls to in new construction.
What is the best way to hang a heavy antique wood framed mirror to a glass wall jimmcfarlane Building & Construction 3 10-11-2012 07:06 AM
heavy rain floods glass slider doors and comes inside. bonster1 Windows and Doors 8 08-26-2012 11:27 PM
Double-hung window sash glass replacement teetee1 Windows and Doors 1 03-10-2012 11:21 AM
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 04:09 PM
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 07:37 AM
