Header Thickness - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 05:24 PM   #1
Header thickness
Hello
I need to install an exterior door in a wall made with 2"x6" studs. What is typically done to build up the header to match the 5 1/2" thickness of the studs? THX
info@homeworkbydave.com is offline   Reply With Quote
Old 11-30-2008, 06:00 PM   #2
i usually lay 2x6 flat on the bottom of the header, with the extra two inches toward the inside. depending on how you want to do it you can either continue with the 16 o.c. or just put insulation in the pocket. you need insulation regardless but you only need every two feet for the drywall. if you just want to you can also put a strip of half inch osb or similar between. alot of choices .
chad4290 is offline   Reply With Quote
Old 11-30-2008, 07:10 PM   #3
Registered User
Termite's Avatar
The header doesn't have to be 5-1/2" wide just because the wall is. Most framers around here use two 2x's and install them tight to the exterior sheathing, unless the loads require a third member.
Old 12-01-2008, 03:55 PM   #4
Drywall contractor
Rewards Points: 1,070
Build a "box" header with a 2"x6" on top and bottom, a 2"x8" nailed flush to the the outer edges. Don't worry about the gap in the middle as KC said unless the span/load requires something solid. That (along with your double top plate) will net you a header height of roughly 83".
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Header in a "modern brace" framed house jtpwils Carpentry 14 11-18-2008 08:24 AM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 08:55 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
