Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-25-2011, 06:38 AM   #1
Header Lenght
I have a basic shotgun home, with 4 add-on's, 1 ea per side L/R, then 2 more back to back on the rear of the home. Kitchen is 12' X 9'4" Really narrow after you put cabinets in. I have a room beside it that I don't really use for anything. I want to remove the wall between the 2 rooms. Yes its the side of the house so its a supporting wall for the roof joist. Ceilings are only 7 foot tall (short) both rooms at same height between them. This room is 16' X 10' , This will give me the openess of kitchen that we want.
Anyone know if a 15 foot 4" I-BEAM would work for a header across this wall. I don't have much head space. This is an older house built with actual full 2 X 4 's rough cut lumber.
Redbeard71901 is offline   Reply With Quote
Old 05-28-2011, 08:46 AM   #2
Header Lenght
You should have it "spec'ed" out by an engineer. I can't see a 4", "I" beam carrying the load over that distance.
Ron
Support for Header Shakemsam Building & Construction 4 12-04-2010 04:38 PM
Garage Header rwbil Building & Construction 11 09-16-2010 12:50 PM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 10:13 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
