Having Trouble W/ Kitchen Layout - Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 03:06 PM   #31
Rewards Points: 558
I have installed kitchen cabinets on pergo flooring before and the last time I did it was 4 years ago and I havenít heard a peep. But if you like you can set the cabinets on the plywood floor and butt the pergo floor to it and then add the toe kick.
epson is offline   Reply With Quote
Old 01-13-2011, 03:13 PM   #32
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
My concern with doing that is sliding the dishwasher in and out. If I have that increased height to deal with from the pergo it could pose problems.
CoconutPete is offline   Reply With Quote
Old 01-13-2011, 03:22 PM   #33
Experienced
Jackofall1's Avatar
The cabinets from Ikea don't come with bases, Ikea has the funky legs, leveling pads and then clipon covers.
This could be an advantage, as you could build your own base allowing for floor variations and levelness.
Old 01-13-2011, 03:24 PM   #34
Experienced
Jackofall1's Avatar
Just add a piece of plywood to the area under the DW to make it level with the finished floor.
Old 01-13-2011, 03:27 PM   #35
Rewards Points: 558
If youíre going to redo the entire floor and all the cabinets sit on the pergo floor then the height for the dishwasher would still slide under the cabinet. If you decide to just leave the dishwasher area with no floor you will still be good to install the dishwasher but when sliding it out you will have a lip from the floor to deal with. Just make sure your dishwasher opening and height are for your dishwasher.
Old 01-13-2011, 03:28 PM   #36
Rewards Points: 558
forgot about that...
Old 01-13-2011, 03:48 PM   #37
Experienced
Jackofall1's Avatar
Forget about what? I thought the cabinets were well made, easy to assemble and very cost efficient.
I chose not to use the legs and made my own base, this allowed me to level the cabinets on a floor that was more than an inch out of level across 16.5', I put a relief cut on the front of the base to allow the hardwood flooring room for expansion.
Old 01-13-2011, 03:54 PM   #38
Rewards Points: 558
No, no what I meant was that I forgot that they came with legs and they can be removed to make your own base.
Old 01-13-2011, 04:04 PM   #39
Hi! what if you did a corner lazy susan in the corner by where the stove currently is, then put the fridge there....then on the wall where the fridge is currently, you can put the stove with a hood or a shelve above it for the microwave, and do cabinets on the sides?
pumpkin8880 is offline   Reply With Quote
Old 01-13-2011, 04:13 PM   #40
Rewards Points: 5,336
There's enough adjustment in the legs of the dishwaser for 1/2" flooring. If you want to be sure, put 1/2" ply under the cabinets to compensate for the flooring.
Ron
Old 01-13-2011, 07:48 PM   #41
Rewards Points: 276
Pete, the kitchen/pantry dining room layout looks and sounds like a traditional setup dating back to the times where rich folks had cooks and wait staff. Is this an old house?
The layout with the stove in its original position and corner cabinet sounds promising. You say that the current layout works well. If you now have no kids or young kids, that layout may not work as well as you add kids or as they get older. Is that outer door a major egress or is it infrequently used? It just looks like the more traffic in and out of that door, the less functional your current setup may become.
One other small thing that may open up the kitchen a little more is if you can recess your refrigerator back into the pantry space so it is even with the rest of the cabinetry. Especially if you stick with 12" as your maximum depth.
Jim F is offline   Reply With Quote
Old 01-13-2011, 08:25 PM   #42
Biaia
JohnnyBop is offline   Reply With Quote
Old 01-13-2011, 09:25 PM   #43
Originally Posted by JohnnyBop View Post
Biaia
Closed head injury?
Ron
Old 01-14-2011, 08:10 AM   #44
Rewards Points: 504
Maybe I posed the question in the wrong way, let me retry:
We are still undecided on what exactly our "dream" countertop is going to be, so because this is not a huge house and we'd like to do the kitchen sooner rather than later, the countertop is going to be butcher block or something like it for the next couple of years. If we love it, we love it. If we don't then it will get replaced at some point. Let's say 2 years from now someone comes in and does a granite or quartz countertop - because of the "springiness" of the pergo w/ the foam underlay I just foresaw BAD news for a stone countertop - does that make sense? I thought plywood sounded like a much more stable base for the cabinets the stone is going to lie on.
Our house is from 1930. I'ts a small Cape Cod and before the addition (1950's) it would have been a 2 bedroom 1 bath house, so I'm not sure where the staff would have lived - it's possible I suppose.
That entrance in the kitchen is driving us pretty nuts.... My wife and I both hate tracking stuff into the kitchen in the winter. I built a deck off the back of the house last summer and the first project when the snow melts is going to be cutting a hole in the wall in the large closet in the den and turning it into a mudroom. That door will be the primary point of entry into the house for anyone who lives there so that door in the kitchen will hopefully become an ornament.
Old 01-14-2011, 08:50 AM   #45
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
In that case, I would do the door/mudroom project first. Have a means of egress, then seal up the door in the kitchen and and use that space against the wall as kitchen area.
You will save money in the long run and be a lot more satisfied with the end product.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
oh'mike (01-15-2011)
Kitchen layout opinion needed ClnlBrahm Kitchen & Bath Remodeling 4 12-29-2010 08:47 PM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 07:59 AM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 02:02 PM
