Hardiplank Directly On Studs - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 04:59 PM   #1
Hardiplank directly on studs
Was reading the install specs on the hardiplank and it says that I can install directly onto studs if they are 16" OC provide i add a moisture barrier like felt. I was a bit surprised and assumed I would need to install over OSB.
What are the cons to installing directly onto the studs..ie will it weaken my structure and will it complicate when I add windows?
BTW this is for an 8' X 12' Shed.
hgullung is offline   Reply With Quote
Old 07-19-2010, 05:16 PM   #2
kwikfishron's Avatar
Rewards Points: 92
You could get away with it on a shed with proper bracing.
I’d never even think about it in a house, to many water management issues.
OSB is down to $8 a sheet in my area. $80 buys you a much stronger structure.
You could easily put your foot through Hardi over studs. You couldn't do that if the wall was sheeted.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
Gary in WA (07-20-2010), Tom Struble (07-22-2010)
Old 07-20-2010, 08:15 AM   #3
Household Handyman
Rewards Points: 1,408
"OSB is down to $8 a sheet in my area."
Send me a truckload, please. I priced this last Friday for a job and it was over $11.00/sheet here, and there is an OSB factory just 30 miles away.
Go figure, David
Old 07-21-2010, 03:53 PM   #4
Rewards Points: 5,336
Go figure, David
That's a lot of kindling. Never had any use for little piecs of wood glued together when plywood is a much better product*
Ron
*Personal Opinion.
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
attaching tub surround directly to studs? upslims Building & Construction 11 04-07-2009 10:39 AM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
Attaching kitchen cabinets directly to studs with no drywall between nrabate Carpentry 7 08-28-2007 10:01 AM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-11-2006 12:10 AM
