-   -   Hardiplank directly on studs (http://www.diychatroom.com/f15/hardiplank-directly-studs-76608/)
hgullung 07-19-2010 03:59 PM
Was reading the install specs on the hardiplank and it says that I can install directly onto studs if they are 16" OC provide i add a moisture barrier like felt. I was a bit surprised and assumed I would need to install over OSB.
What are the cons to installing directly onto the studs..ie will it weaken my structure and will it complicate when I add windows?
BTW this is for an 8' X 12' Shed.
kwikfishron 07-19-2010 04:16 PM
199 Attachment(s)
You could get away with it on a shed with proper bracing.
I’d never even think about it in a house, to many water management issues.
OSB is down to $8 a sheet in my area. $80 buys you a much stronger structure.
You could easily put your foot through Hardi over studs. You couldn't do that if the wall was sheeted.
Thurman 07-20-2010 07:15 AM
"OSB is down to $8 a sheet in my area."
Send me a truckload, please. I priced this last Friday for a job and it was over $11.00/sheet here, and there is an OSB factory just 30 miles away.
Go figure, David
Ron6519 07-21-2010 02:53 PM
Go figure, David
That's a lot of kindling. Never had any use for little piecs of wood glued together when plywood is a much better product*
Ron
*Personal Opinion.
