Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-27-2010, 01:10 AM   #1
Hardie over Masonite siding???
Hello All -
It is night so I will get a picture up in the morning.
I am pretty sure it is Masonite Siding, excuse if I am wrong.
The front of the house which faces south has which I believe has Masonite lap type siding and the the rest of the home is stucco
Alot of the other homes in the neighborhood (all been custom, most built within a couple of years of each other) has Hardie Lap Siding and the homeowners really like it
Have seen a lot of problems with this same siding, which I believe is Masonite, they want to change it over to a Hardie
The trim and siding appears to be in great shape
My question is can you side with Hardie lap siding directly over this???
I will get pictures up asap.
Or do I need to rip it all off, go back to the plywood or OSB and re tyvek and go from there???
Thanks,
Mike
canyonbc is offline   Reply With Quote
Old 01-27-2010, 01:50 AM   #2
Tom Struble's Avatar
best to pull it,that will keep your trim and siding elevations the same
Tom Struble is offline   Reply With Quote
Old 01-27-2010, 09:57 AM   #3
Windows & Remodeling
HomeSealed's Avatar
Do not put Hardie over masonite. Rip off the old siding, do it the right way the first time.
HomeSealed is offline   Reply With Quote
Masonite siding chard Building & Construction 4 02-28-2009 05:12 PM
Best caulk for Hardie Plank siding? Solar Dave Building & Construction 7 09-28-2008 09:02 PM
Hardie Board Siding and Wind gordo409 Building & Construction 2 07-10-2007 07:00 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
