-   -   Hardibacker Cement Board Thickness Issue With Drywall (http://www.diychatroom.com/f15/hardibacker-cement-board-thickness-issue-drywall-139487/)
JasonCA 04-06-2012 10:26 PM
Hi Everyone,
I've heard that 1/2" Hardibacker thickness doesn't quite compare to 1/2" drywall thickness. And I've not found a good answer as to how to get Hardibacker flush with drywall?
Because of this, I've been considering using 1/2" Durock instead since it would seem to be more flush with 1/2" drywall, ....:
However, in my research I have found that there are many who have complained about Durock Next Gen's cement being of a lower quality product then the original Durock. The complaint is that Durock Next Gen seems to use less cement? In other words, they argue that Durock is saving money as company while consumers receive more of an inferior product by taking the good building material out of the cement board and putting lower quality product into the cement board.
Also, I've heard Durock Next Gen is a bit more flimsy then the original Durock cememnt board. I think they stopped making the original Durock in 2009 (could be wrong)?
Durock Next Gen also seems to not take screws easily and seems to be finicky at the edges.
I'm not how correct the above complaints truly are, but it's made me more prone to want to use Hardibacker.
[Main Question]:
The problem with Hardibacker is it doesn't seem to go flush with 1/2" drywall? If this is true, what are some solutions to this problem?
I am down to the studs. So, I was told that putting 1/2" Hardibacker up to the studs next to 1/2" drywall that is up to the studs would result in a joint that isn't flush? If so, this is a problem. And I'm not sure how to best resolve this.
Anyone have suggestions or comments?
Thanks,
Jason
joecaption 04-07-2012 12:36 AM
Not sure where your getting this info but I for one have never had it be an issue.
AtlanticWBConst. 04-07-2012 05:20 AM
Just use the Durock and you won't need to worry about any possible thickness differences. We prefer Durock for all tile related installation anyways.
As far as screws go = Are you using the correct Durock coated screws?
ratherbefishing 04-08-2012 12:10 PM
Hardibacker 500 is .42 inches thick. (Maybe this is to allow for the thinset and tile?)
http://www.jameshardie.com/homeowner...halfInch.shtml
I am currently working on a bathroom using 1/2" Permabase. It matches up with 1/2" drywall just fine.
CraftsmanConnec 02-24-2013 01:00 AM
Reply to the Cement Board / Drywall thickness
I'm pretty sure they designed the 1/2" Hardibacker (.42") to have tile on it which need mortar 1/4"x1/4" notch will produce a 1/8" height (.125). So when you typically have 1/2" (.500") drywall plus a light texture 1/16" (.0675) (orange peel or knock down) and have tile butting up to it as if coming out of a shower area, then it is really close to being flush .545 compared to .5675. Less than 1/32" difference. Your welcome.
Yes Pre-drill with the screw, and put the drill motor in reverse and using an orbital motion round out the hole bigger like a countersink bit would, then drive the screw in. I've been doing this for years.
Originally Posted by JasonCA (Post 893413)
Hi Everyone,
I've heard that 1/2" Hardibacker (.42") thickness doesn't quite compare to 1/2" drywall thickness. And I've not found a good answer as to how to get Hardibacker flush with drywall?
[Main Question]:
Thanks,
Jason
