Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-29-2012, 02:02 PM   #1
Hanging Shutters in brick - anchors?
Hi all, I browse here now & then and am in need of some advice. I have some shutters I need to hang on brick. There are some plastic screws that came with the shutters, but no anchors. The screws are pretty thick, maybe around a 5/16 or 3/8 bit size. They are also about 2.5 in. Long. Anchors did not come with the shutters, and the varying anchors I do have wouldn't fit w/ the screw. I checked at a lowes and spoke w someone who showed me the same plastic anchors I already have which won't work. What am I missing here? Is there a specific anchor I need? Also, I heard its good to put some caulk in behind the anchors, does that sound right?
Thanks!
Mr.Tryng2fxit is offline   Reply With Quote
Old 03-29-2012, 02:14 PM   #2
DIY Enthusiast
sublime2's Avatar
Mine were done old school.
Drill holes,cut/rip some small pieces of wood and force/hammer them into holes like a wedge then screw in.
sublime2 is offline   Reply With Quote
Old 03-29-2012, 04:50 PM   #3
Civil Engineer
For brick, I prefer lead shields with stainless steel screws. Typical shield is about 3/4 inch long, perhaps 3/8 inch to 1/2 inch wide, and should come with a screw designed to expand the anchor. Use the correct size drill, and these installs are pretty bombproof.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
concretemasonry (03-29-2012)
Old 03-29-2012, 05:08 PM   #4
Jack of all - master none
hyunelan2's Avatar
Tapcon?
http://www.tapcon.com/
hyunelan2 is offline   Reply With Quote
Old 03-29-2012, 05:54 PM   #5
STAFF
BigJim's Avatar
Those plastic screws are made to dive in not screw in. I always drilled a hole use a short piece of single strand romex and used deck screws, holds great and can be removed easily.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 03-29-2012, 06:22 PM   #6
"Nail-Bender"
5/32nd. "tapcon" bit -
small strips of aluminum -
2" - 2 and 1/2" deck screws - 8 gauge.
It's been working for 30 plus years.
(Oh no, "galvanic action"?!? - somewhat)
"RF"
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
BigJim (03-30-2012)
Old 03-30-2012, 11:55 PM   #7
This is how we attached plastic shutters to block homes at work, not sure if it will be great with brick but I don't see why not:
We drilled holes in the shutters, positioned them on the wall, marked the block where the holes were, and drilled 5/16" holes in the block with a masonry bit and a hammer drill. Put 5/16" plastic anchors in the holes, and mounted the shutters to the anchors with large head screws(looked better than regular exterior screws.) Painted the screws to match the shutters, and called it good.
Worked out well, they've stood up to the elements here for the past couple years at least. Wood shutters, you may want to use a heavier duty anchor, the plastic ones we put on didn't weigh a thing.
AZJefe is offline   Reply With Quote
Old 03-31-2012, 12:01 AM   #8
DIY Enthusiast
sublime2's Avatar
What ever anchor you decide to go with be sure to drill your hole 1/2" to 1" beyond the size of the anchor so as not to bottom out the screw.
particularly the tapcon screws!(which i would not use)once they grab that brick you can easily snap the head off them then our screwed.
Fasten anchors into the brick or the mortar? spaceman spif Building & Construction 12 08-02-2011 09:08 AM
Hanging a joist in an 1895 brick wall billydwilliams Building & Construction 4 03-28-2011 04:09 PM
Hanging Heavy Sign Post - Into Brick or Mortar? nikky_hack Building & Construction 6 11-17-2010 04:04 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Drilling asbestos siding (hanging shutters) MichaelDutch Remodeling 3 06-15-2010 11:49 AM
