-   -   Hanging sheetrock questions. (http://www.diychatroom.com/f15/hanging-sheetrock-questions-20328/)
rwk0930 04-25-2008 03:24 PM
I am about to begin the sheet rock phase of finishing my basement and had a couple of quesitions. I am using 4x8 sheets. Is it easier to work from top down or bottom up? Do you need to level your sheets by snapping a line or will the I-joist be level enough? I do beleive you need to stagger your joints, but a friend of mine laid them up the long way (8' up and down) to cut down on the seams, but is that a bad idea? Any other suggestions before I begin the project?
Thanks for your help.
AtlanticWBConst. 04-26-2008 05:42 AM
It depends on these factors:
1.) Are you installing a sheetrock ceiling, or soffits? If so, then you should always install the ceiling and soffits (upper areas) first...then the walls.
2.) Are you installing an acoustic type ceiling? If so, then you can install the walls from the bottom up. I suggest that you use some 1/2" or 3/4" Scrap wood to lay on the floor as spacers, then rest your first sheets (lower sheets) on those.
The I-joists should be level and can serve as your straight edge.
Yes, absolutely, you should 100% of the time, stagger all Butt Seams. Standard installation in residential structures, including basements, is to lay the sheets down. Doing so will also create less/fewer seams to tape and coat (than if you were to install the sheets vertically).
That's all I have time to write.
Reference these links:
http://64.78.42.182/sweethaven/BldgC...sp?iNum=040204
http://www.cgcinc.com/pdf/howtos/j371.pdf
http://www.homeadditionplus.com/Dryw...stallation.htm
http://www.vertri.com/sheetrock_ceiling.html
http://www.hometime.com/Howto/projec...all/drwl_4.htm
Good Luck.
