Hanging New Interior Doors - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-29-2007, 09:56 AM   #1
Unhappy
Hanging new interior doors
I just got a good deal on solid wood prehung doors to replace the existing doors in my house...but when I went to put them in I realized that 4 1/2 inch width jambs were 1/2 inch too small for the existing space in my wall. What do I do? Return the doors & special order, or is there a more cost efficent solution to my problem?
DarenC is offline   Reply With Quote
Old 08-29-2007, 02:18 PM   #2
Is it safe to assume the new doors units are split jamb?
Measure twice cut once goes for door jambs also. Measure all of them.
Cost effective solution? take them back if you can.
Lot's of shimming, double nailing, milling Stop extender lumber, plumb & leveling.
It can be done, but it will take 10 times longer even with the right tools and skill level.
How did you end up with 5 inch interior walls? Sounds like they double rocked one wall.
Maybe to cover 4 layers of wall paper?
Big Bob is offline   Reply With Quote
Old 08-29-2007, 07:38 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Create 1/2" extension jambs with the correct wood stock and a table saw. Use wood shims to properly align the ext. jambs and attach with a brad nailer or 18g stapler. Then install your casing.
- Build Well -
Old 09-01-2007, 03:58 PM   #4
remodeling pro
Please tell me it is not so...heavy solid doors available with split jambs
Yea, either a rock over or old plaster walls IMO also.
Like most "great deals" in the end they cost more than the correct item. Sure , you can extend the jambs, but they will always look exactly like an add on. I'm with BigBob, get the correct jambs to begin with and make your life easier.
troubleseeker is offline   Reply With Quote
Old 09-02-2007, 08:44 AM   #5
Troubleseeker, The poster got a "good deal" on the doors, and remember that they also asked for a "cost efficient" way to alter the door jambs....
So they are looking for a ''low-budget'', DIY-level, solution ....
- Build Well -
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 11:21 AM
Help hanging heavy punching bag from ceiling chrisski1991 Building & Construction 5 03-15-2007 07:46 PM
Hanging a beam/rafter from a beam snmhanson Building & Construction 4 01-11-2007 10:37 PM
Hanging towel bar in hollow core door. ERIK2173 Remodeling 1 02-06-2006 07:19 PM
Hanging a Wallpaper Border Nathan Painting 10 06-17-2005 01:19 PM
