Hanging Crown Molding In Florida Condo - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 02:17 PM   #1
Hanging crown molding in florida condo
Looking to hang crown molding in condo with concrete ceiling and metal studs thinking about using furring strips 1x2 to nail it to looking for any other ideas besides this method. Thanks
Mhultquist is offline   Reply With Quote
Old 01-26-2011, 02:39 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Attach a piece of colonial base to the ceiling and to the wall, then mount your crown to that
Your crown will hide all the ugly fasteners that you use to screw the base to the metal studs and tapcon the ceiling base to the concrete ceiling.
tcleve4911 is offline   Reply With Quote
Old 01-26-2011, 04:01 PM   #3
Thanks but we were thinking less expensive route so we are nailing the crown to the furring strip and caulking it in
Old 01-26-2011, 04:08 PM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Then I know of no other method..................
Old 01-27-2011, 01:00 PM   #5
Rewards Points: 5,336
You can cut triangular nailing blocks that get set 16" on center around the room. Use adhesive to hold glue them to the wall/ceiling and shoot a nail in each one to keep it in place until the adhesive dries.
Shoot the molding into the nailers.
Ron
Old 01-27-2011, 07:57 PM   #6
Cleve's idea is great (thanx Cleve). If you cant afford all that baseboard, use 1x6, run a router down each edge and rip it in half . An ogee bit is pretty close to that colonial base.
Dwoodsmith is offline   Reply With Quote
The Following User Says Thank You to Dwoodsmith For This Useful Post:
tcleve4911 (01-27-2011)
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 05:20 PM
making own crown molding marin001 Carpentry 7 03-28-2010 11:08 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 07:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 12:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
