Hanging Basement Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 05:05 PM   #1
Hanging basement ceiling
I have a couple questions before starting to board my basement. My basement is framed however ceiling is just joists. Do i need to run strapping before hanging board ? As there is just a gap between all exterior walls and joist.
Pubby is offline   Reply With Quote
Old 04-05-2012, 05:09 PM   #2
Rewards Points: 12,790
Post a picture of this gap.
Are the walls already done?
The reason I ask is the ceiling was suppost to go in first.
You are going to rent a drywall lift right?
Old 04-05-2012, 05:12 PM   #3
Framing of walls no drywall though. Ceiling is just all joists no strapping.
Old 04-05-2012, 05:27 PM   #4
Example...exterior wall then a foot gap to first joist. So nowhere to screw drywall to against wall. If you understand what i mean.
Old 04-05-2012, 09:28 PM   #5
No need for strapping just install some backing to the top of the top plate so that you can screw the drywall to it, or you could use drywall clips.
kj6887 is offline   Reply With Quote
Old 04-06-2012, 07:59 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I suggest you install the strapping and run it long under the open space on that exterior joist bay. That additional length of strapping can serve as a nailing point for your new exterior basement wall, should you need it.
It would be very difficult to get up into the outside rim joist bay to install nailers, as the previous poster suggested (Tho that concept will work on interior joist bays).
Realize that conventional lumber joists all have what is called a crown and can also vary slightly in actual width dimenions (as much as 3/8" +/-). Because of that, you will have some variations in the linearity of the overall runs under the joists (undersides not all completely at the same alignment/level).
Adding strapping will allow you to; run light fixture (and other) wiring without having to drill through every joist. It also allows for more level and even sheetrock attachment, and at the same time - it creates attachment points for any new basement walls that will be perpendicular to the overhead joists.
- Build Well -
Old 04-06-2012, 08:11 AM   #7
Thank you very informative. All my wiring is already ran (bought house like this) and is drilled through joists. Does this make any difference ? So are you saying run strapping over whole ceiling perpendicular to joists? If so would it provide enough stability having that foot of strapping not attached to anything ? Or at that point should i run a piece from ceilig down to attach overlying strapping to?
Old 04-06-2012, 08:14 AM   #8
It will be perfectly stable for an exterior basement renovation wall. Trust me; after you do it, you will be able to put 4 guys against that wall (pushing and pulling) and it will not budge.
- Build Well -
Old 04-06-2012, 11:56 PM   #9
Registered User
Rewards Points: 4,888
As the wiring is already in (add canned fire-foam in the holes to localize any fire to that one joist cavity), I usually add lengths of metal "L" flashing at the joist line to screw the ceiling drywall to-- if past the maximum fastener spacing distance, Post # 6 and #10:
Gap B/ween Ceiling Corner Rafter and Top Plate -- Acceptable Or Not?
Of course, if the bathroom is small, strapping is easy....
Gary
Old 04-09-2012, 03:44 PM   #10
here are a few pictures of what i am talking about. ps..the drywall was hung on that one wall when i bought house, and will be coming down and redone.
Hanging basement ceiling-photo.jpg   Hanging basement ceiling-photo-1-.jpg   Hanging basement ceiling-photo-2-.jpg
Old 04-09-2012, 03:45 PM   #11
also, sorry for sideways pictures.
Old 04-09-2012, 04:01 PM   #12
DIY Enthusiast
sublime2's Avatar
Looking at the pics, your going to need nailers around the perimeter above the wall framing to secure the rock on the ceiling.
Don't see a need for strapping on the joist either.
When you go to hang the rock on the ceiling make a "T" out of some 2/4 lumber the height of the ceiling including the rock and use them to hold the rock up while you screw it in.
sublime2 is offline   Reply With Quote
Old 04-09-2012, 11:33 PM   #13
Rewards Points: 2,202
Nail up some backing 2x4 or metal L's
mae-ling is offline   Reply With Quote
Old 04-10-2012, 12:43 AM   #14
Registered User
Plug those wiring holes with canned foam. Install wood fire-blocks or other at drop floor elevation. Garbage the poly unless required by local AHJ; http://www.buildingscience.com/docum...study-analysis
http://www.buildingscience.com/docum...ts?full_view=1
Gary
Old 01-08-2013, 12:23 PM   #15
Could someone possibly post a picture of what you mean ?
Commercial Electric Pot Lights in Insulated Basement Ceiling balithecat Electrical 4 03-14-2011 06:46 PM
How to lower basement ceiling salman_z8 Building & Construction 9 03-02-2011 11:26 AM
How to Lower Basement Bathroom Ceiling JDC4NU Building & Construction 3 03-01-2011 12:19 AM
HELP! Ceramic tiled ceiling in basement bathroom.... jrutherford Remodeling 1 10-11-2010 01:27 PM
Drywalling my basement ceiling luweee Remodeling 5 03-24-2009 07:58 PM
