Half Wall With Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 12:04 PM   #1
half wall with door
Hi! I'm new to this site and sure hope there's someone (or lots of folks) who can help me. To begin with, I'm not sure if I'm in the right area - I considered the catagories of drywall and/or interior decorating, so if I'm in the wrong place, please forgive me.
Here's my situation: I'm a licensed, accredited child care provider. The children I care for spend a lot of time in my family room; because they are all under the age of 2 years, I need to keep them separated from my kitchen. Currently I use a 10+' long gate, but in the center of the gate is a swing opening and the force of repeated pushing against it has literally broken it off of its hinges and my husband has had to wire it shut.
This means I have to step over the 3 ft. high gate, with a little one in my arms. And it's getting worrisome, especially when the child I'm holding begins to wiggle!
What I want is a firm, sturdy, half-wall, with a center opening, such as a half door - something that can be securely closed and opened only by an adult.
Any ideas?
FYI, we own this house, so we can definitely do whatever it takes to making this barrier secure, without asking permission.
Many thanks!
MsLucy is offline   Reply With Quote
Old 02-02-2010, 01:10 PM   #2
Rewards Points: 5,336
Don't really understand the question. Do you want to know "how" to build the wall and door? Think of it like a fence with a solid gate. Just put the latch on the side the rugrats can't reach.
Ron
Old 02-03-2010, 10:58 AM   #3
half wall
Sorry for not being clearer - part of what I want is to understand HOW to build some sort of stury, functional partition, with a gate. The other thing I was hoping to get was ideas on what would look and work best.
Right now I'm considering long, bookcases that would need to be fixed to the wall and floor and try to put a gate between them. But I'm open to other thoughts.
Thanks for your time.
Old 02-03-2010, 11:46 AM   #4
If you like the bookcase scenario, do that. Just cap the bookcases with a piece of wood, the same width, so it ties the various components together. You can make a door for the opening out of wood and secure the door with a barrel bolt.
Ron
Old 02-03-2010, 03:58 PM   #5
Question
half wall
Thanks - now if I only understood what "cap the bookcases" means!
Old 02-03-2010, 04:16 PM   #6
It will be a piece of wood the length of each bookcase wall. It unitizes the individual bookcases into one unit. This way they don't move as easily as one would.
Ron
How to strengthen up a half wall zetti1102 Carpentry 6 11-06-2009 09:17 PM
Cutting into foundation wall to install entry door. notenoughtime Building & Construction 7 08-19-2009 03:13 PM
Making a load bearing wall a half wall vjbozard Building & Construction 9 04-12-2009 04:11 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Door frame against stone wall elliowb Carpentry 8 12-14-2007 05:03 PM
