| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Installing Shower Walls
by expertvillage
Find out the best way to put in shower walls. Learn how to add a new bathroom to a home, including tips on putting in shower walls in this free home improvement video. Read More »
How to Unclog a Shower Drain
by Tim Gipson
Unclogging a drain can be done with commercial chemicals or by using a natural unclogging agent like baking soda, vinegar and hot water. Unplug a shower drain with other methods like a coat hanger or plumber's snake with tips from a home repair... Read More »
How to Unclog Shower Drains
by Tim Gipson
Unclogging a shower drain may require using a hanger or plumber snake if the pipe is clogged with hair. Try using commercial grade chemicals to unplug a shower drain first with tips from a home repair specialist and remodeling contractor in this free... Read More »
Advice on Tiling Walls
by Stephen G. Anthony
A homeowner that is replacing bathroom wall tiles should use a cushioned surface for tile pieces to fall on. Use a steamer to take the old adhesive off of a wall before applying new tiles with help from a professional carpenter in this free video on home... Read More »
How to Clean a Ceramic Tile Shower
by Rachel Yatuzis
Ceramic tile showers should be cleaned every six weeks, and this can be done through a simple once-over with vinegar and water. Make a paste of baking soda and vinegar for cleaning the grout in between ceramic tiles with help from a professional house... Read More »
