Gutting A Bedroom/s - Am I Nuts? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 11:25 PM   #1
Gutting a bedroom/s - Am I nuts?
I live in a 3 story condo building on the second floor. The new neighbors upstairs are exceptionally noisy, mostly walking around on their heels so hard our light fixtures shake. I've brought it up a few times, but nothing ever changes. I have a bit of experience in recording studio design, so I have been tempted to gut both bedrooms, and install roxul, then a resilient channel and then rehang the drywall. Currently, there is no insulation between the floors, or any cork under the wood floors. I could easily handle the demo, insulation and installation of the resilient channel. I would probably hire someone to haul the drywall up the stairs, hang it and tape. The one bedroom is very square, about 180-200 square feet, and the second one is slightly more complex, but about 200-225 square feet.
My questions are:
Would it really be worth it?
What would my estimated cost be for labor? (I've calculated materials)
Any other methods that would be more effective?
Am I nuts?
davehk is offline   Reply With Quote
Old 04-02-2012, 11:32 PM   #2
Rewards Points: 12,882
Your not nuts and it sounds like a good plan. One of the hundred or so reasons to never buy a muliti family dweling.
Old 04-02-2012, 11:37 PM   #3
To be fair, the people that lived up there for the first two years must of floated around an inch off the ground because I never heard them once.
Old 04-02-2012, 11:42 PM   #4
Was there flooring changed?
Old 04-02-2012, 11:45 PM   #5
Nope, just the neighbors. The difference between someone that shuffles when they walk, and someone that walks directly on their heels. The place is a good investment though, and I see a project adding a lot of value when it comes time to sell. I would definitely document it and take pictures and use it as a selling point..
Old 04-02-2012, 11:49 PM   #6
I hope it all works out for you I know around here you could not give away a condo.
It's always best to go back and add your location in your profile for better ansewers.
Old 04-02-2012, 11:55 PM   #7
Good call, around here, there is still a good market for condos, and we got in after the crash.
Old 04-03-2012, 12:41 AM   #8
Registered User
Rewards Points: 4,936
Check with your condo association and building dept., as there may be restrictions and fire separation rules/laws you are unaware of...Get a permit if only for the paper trail for H.O. Insurance carrier.
Gary
The Following 3 Users Say Thank You to Gary in WA For This Useful Post:
AtlanticWBConst. (04-03-2012), creeper (04-03-2012), kj6887 (04-03-2012)
Old 04-03-2012, 06:50 AM   #9
When you figured your material cost did you figure 5/8 gyp. I am sure that will be required for fire, also have you looked into any of the sound deadening drywall? I have heard some good things about it, but as stated above have a paper trail.
kj6887 is offline   Reply With Quote
Old 04-03-2012, 05:54 PM   #10
I did factor in 5/8 drywall, the whole unit is 5/8". The condo association isn't an issue, and permits are not needed for drywall. (in chicago at least).
In most studio builds I would use normal 5/8" and in critical applications, two layers with green glue in between. We never used the resilient channel on the ceiling however, since we were always building a room within a room. Would it be acceptable to hang drywall on the ceiling using the resilient channel? The mechanical decoupling is critical and would have the largest impact on sound proofing.
Stuck faucet valve steam has no hex/packing nuts? leemort Plumbing 20 02-25-2012 05:28 PM
Price Phister - no riser nuts? rjniles Plumbing 1 03-18-2011 09:31 PM
How to fasten heater element nuts under dishwasher? darsunt Appliances 0 12-04-2009 12:21 AM
Impact gun not removing lug nuts n0c7 Tools 10 06-18-2008 04:20 AM
hold the nuts! (wire nuts that is) analogmusicman Electrical 6 05-25-2008 12:34 PM
