Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-22-2010, 09:38 AM   #1
Grout sealer advice
this is a double question
we just put in some decorative stone in our bath, our contractor used an enhancer sealer prior to putting in grout, I must admitt it really makes it looks nice, after putting in the grout, he said he was using a clear sealer, becuase the enhancer will change the color of the grout?I do like the look of the enhancer, is this a good move using clear? can you still use enhancer down the road some time if we want to>?
also, I noticed now that he is putting in the grout, slight imperfections in the stone (find lines) are accepting the grout as well, so you see all these light grout lines in the stones, how can this be removed?
turbomangt is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Grout sealer on porcelain tile. sukhenkoi Tiling, ceramics, marble 5 04-28-2010 04:51 PM
Grout sealer before or after silicone caulk ? SPS-1 General Discussion 2 07-28-2009 10:30 AM
Applying grout sealer on vertical wall tiles MT Stringer Remodeling 2 06-02-2009 06:17 PM
advice on tile/grout sealer for polished marble in shower marcin1 Flooring 4 05-18-2008 07:59 AM
