Grout Cracked And Holes - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 11:13 PM   #1
Grout cracked and holes
Besides re grouting or caulk is there any other product that bonds really well to grout in a shower?
campbellc1 is offline   Reply With Quote
Old 02-08-2012, 11:17 PM   #2
Rewards Points: 13,260
If it keeps failing it may be because the tiles were applyed over drywall and it's failing.
Try pushing on the tiles. There should be 0 movement.
Old 02-08-2012, 11:21 PM   #3
if its in a corner remove the grout and caulk it with silicone. you can get silicone caulk to match the grout.
Old 02-09-2012, 01:26 PM   #4
There is zero movement. So it sounds like caulk is the only way to go besides re-grouting. I know usually a concrete board should be used in a shower before the tiles are applied. Just hate pulling out grout.
Do I just remove the grout in that one area or are we talking the whole shower?
Old 02-09-2012, 08:25 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
How about a pic so we know what you're talking about.
cracked oustside basement wall Hera Kashmeri Building & Construction 1 06-14-2011 07:16 AM
'hard patching' blast holes in concrete warehouse floor shag_carpet Flooring 0 09-08-2010 05:29 PM
Cracked Floor Joist - what to do? Knucklez Building & Construction 25 08-10-2010 02:21 PM
Foundation Tie Holes - How to fill? globus999 Building & Construction 10 06-28-2010 11:14 AM
Cracked drywall at joint near door? ClemsonJeeper Drywall & Plaster 6 11-06-2009 04:27 PM
