GROUT, COLORED SILICONE, Or CLEAR? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 12:53 PM   #1
GROUT, COLORED SILICONE, or CLEAR?
HELLO,
I have just re tiled around my whirlpool tub in my bathroom. I have tiled the deck as well as the backsplash. Where these come together at the base of the wall. should i just grout this area and then go back over the seam with a clear silicone or only use a colored silicone along the seam where these two (wall and deck) meet?
In my kitchen, i was told to use the colored silicone at the base of the backsplash where it meets my countertop. Is this the same, or should i just grout it all, then go back over that seam with a clear silicone?
asiatheboxer is offline   Reply With Quote
Old 09-05-2011, 02:18 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
First of all I would get the notion of using silicone out of my head entirely. I would suggest you use grout-matching colored CAULK. The caulk can be siliconized if you just want to use the word. 100% silicone is available in many colors but is difficult to find and may be special order. 100% silicone makes a heck of a mess that isn't easy to clean up and can ruin a nice tile job.
XXX
Old 09-05-2011, 04:42 PM   #3
ok, you are right... that is what i used. Grout colored chaulk for my kitchen. so i guess you are saying to use the same thing around the base and not just grout .. RIGHT?
Old 09-05-2011, 05:13 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
RIGHT?
Correct!
XXX
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 02:01 PM
GE Silicone II won't adhere to grout astroboy Flooring 9 11-11-2010 09:21 PM
Removing color from colored grout jeffmn Flooring 2 10-16-2009 09:10 PM
Grout sealer before or after silicone caulk ? SPS-1 General DIY Discussions 2 07-28-2009 09:30 AM
silicone caulking over ceramic tile grout joints tonyg2 Flooring 5 11-16-2008 08:48 AM
