Greenboard Around New Tub/surround - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-23-2008, 07:33 AM   #1
Greenboard around new tub/surround
I need to install greenboard around a new tub/surround. Right now there is a two inch space above and around the new surround. Spacing resulted from the removal of the old unit.
How far out from the unit should I cut and replace the greenboard? 1 stud - 2 studs?
Also, in most construction, is the ceiling wallboard put up before the walls?
Thanks for your help.
dfhsah is offline   Reply With Quote
Old 02-23-2008, 09:41 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by dfhsah View Post
...How far out from the unit should I cut and replace the greenboard? 1 stud - 2 studs?
You might as well go the 3" out along the vertical length of the shower/tub surround.
However, I suggest that you not use MR board. Consider one of these choices (I believe that all the Big HomeImprovement Stores are carrying them now):
XP Board: http://www.nationalgypsum.com/products/product69.aspx
Paperless Drywall: http://www.gp.com/BUILD/product.aspx?pid=6353
It is standard procedure to put the "lids up first". That means, ceilings are always hung first.
- Build Well -
How to finish the corner where the tub/shower meets the new greenboard J187 Remodeling 19 08-27-2008 02:41 PM
greenboard or hardibacker hms Building & Construction 6 04-01-2008 11:44 AM
Concrete backerboard vs. Greenboard amakarevic Building & Construction 1 05-22-2007 05:54 AM
I'm going to end up with a seam of greenboard meeting plaster, how should I finish? J187 Building & Construction 2 06-06-2006 07:53 AM
Need to Join some walls together. Need advice on a couple of things *Pics* J187 Building & Construction 4 05-20-2006 04:45 PM
