Gravel Crawl Space. Plastic Vs Concrete - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-18-2008, 11:38 AM   #1
Gravel crawl space. Plastic vs concrete
I have a gravel crawl space and looking to keep out the moisture and place insulation. It is best to install a thick plastic, or have a concrete floor poured. It's only $4k for a interior drain tile and 3-4" on concrete, but not sure if pumping concrete, that has water content, is good to have inthe crawl space. Granted the mosture will go away once the concrete cures, but is all moisture in the air good?
howard.wheaton is offline   Reply With Quote
Old 10-19-2008, 12:12 AM   #2
Registered User
Termite's Avatar
The moisture in the concrete isn't evaporated, it is chemically utilized in the hydration process. I'd have no moisture-related concerns about placing concrete in a crawl space. None at all.
If you do concrete, use a 6mil vapor barrier under it for good measure.
Vapor Barrier for Crawl Space. What mil plastic? twilightcall Building & Construction 13 03-30-2012 11:31 AM
Gravel crawl space. Plastic vs concrete howard.wheaton General DIY Discussions 14 12-04-2008 09:39 AM
Installing concrete floor in crawl space timchi29 Building & Construction 3 09-16-2008 08:31 PM
concrete foundation with a crawl space agrenvik Building & Construction 1 03-25-2008 08:27 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
