Granite In Minneapolis Area??? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 05:44 PM   #1
Granite in Minneapolis area???
Hi,
Can anyone recommend a discount place that sells slab granite? I am overwhelmed with all of the granite places out there and I am really just looking for an inexpensive place to order from.
Thanks for any tips.
simiesue is offline   Reply With Quote
Old 02-24-2011, 05:51 PM   #2
Rewards Points: 5,336
Originally Posted by simiesue View Post
Hi,
The cost of a granite counter top isn't just predicated on the slab price, unless you'll be fabricating it or want a really big island.
Ron
Old 02-24-2011, 06:04 PM   #3
I was looking for maybe a remnant piece of granite that can work in my kitchen. Not sure if regular granite showrooms carry remnants or is there a special place to shop for it.
Old 02-24-2011, 06:19 PM   #4
Fabricators cut the granite up and profile the edges. All fabricators have various sized pieces left over you can check out.
Ron
Old 02-24-2011, 07:41 PM   #5
Household Handyman
Rewards Points: 1,408
simiesue" Depending on what you are calling a "remnant piece" of granite and what size--you might be able to find what you want at a local cabinet shop or a monument place. I have obtained, FREE of charge, pieces that were cut out for sinks. The shops around here have to throw them away as they have no use for them. I have a granite cutting board in the kitchen, a granite piece in my shop I use as a make shift "surface plate" and as a flat surface to sharpen my wood chisels and hand plane blades on. You can't be too choosy as to pattern or color with these, but they work. The edges are not really smooth, but dress out nice with certain grinding disc.
Old 02-25-2011, 06:43 PM   #6
Rewards Points: 660
I haven't been there in awhile, but the last time I was there the ReUse center at Lake and Hiawatha had a decent selection of big pieces.
Building Materials Outlet in Eagan.
B
Beepster is offline   Reply With Quote
Old 03-01-2011, 11:34 AM   #7
Remodeler
JCarsten's Avatar
If you can't find the slab you need, the granite company I use for fabrication and installation is Granite Tops.
http://www.granite-tops.com/
They charge for the actual square footage, not the entire slab (for most types of granite).
Jason Myrlie
www.jcarstenhomes.com
JCarsten is offline   Reply With Quote
Old 03-07-2011, 10:46 PM   #8
Rewards Points: 262
be sure to choose your granite installer carefully. A good price now can cost you in the long run. Not saying this guy went cheap, just saying you don't want a similiar experience. Is this a lousy granite installation?
Jim F is offline   Reply With Quote
granite transformations El Toro Remodeling 240 12-04-2014 12:29 PM
Need a remedy for Hole drilled too big in Granite ginnieny Plumbing 6 11-10-2010 10:27 PM
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 01:03 PM
Granite backsplash over beadboard? Asil65 Building & Construction 10 03-23-2009 12:02 PM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
