Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-10-2006, 08:03 PM   #1
granite counter top cutting
Does anyone know what type of cutter and how to polish granite counter top. Just need to do a straight cut.
trifit1 is offline   Reply With Quote
Old 02-12-2006, 09:30 AM   #2
sub-contractor
It depends on how long of a cut...or should I say, how steady are your hands?:p
When I install a kitchen with a granite or marble countertop, I ALWAYS have a company come out to install their pre-measured pre-cut countertop. but when they come out, they usually have to do a little "massaging" to the backsplashes. They trim them with high powered grinders with special diamond tipped cutting wheels, and then buff them with some sort of a buffing wheel.
If you called any kind of marble and granite company, they will be able to fill you in. Possibly even be able to cut your piece too. For a price........:D
Aceinstaller is offline   Reply With Quote
Old 02-12-2006, 07:56 PM   #3
Agreed, have someone do it for you, just a straight cut isn't too hard with an angle grinder and diamond blade, clamp a straightedge down as a guide, but polishing will cost ya a few hundred $ or more just for the diamond pads and you'll need a variable grinder as well, and these will only polish it, not put any type of bullnose on them if that is needed.
R&D Tile is offline   Reply With Quote
Corian or Granite counter tops Jms92 General Discussion 21 04-17-2010 07:18 PM
Pass-thru counter gshock Carpentry 6 07-29-2007 12:44 AM
Decorative Etched Granite Listello csteinke Remodeling 1 06-09-2007 12:54 AM
Anyone experienced cutting granite? Bigman610 Remodeling 4 05-04-2007 02:16 PM
installing granite counter tops dnassif Remodeling 4 07-01-2006 09:37 AM
