Granite Bullnosing/polishing - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 01:06 PM   #1
AGWhitehouse's Avatar
I have bought granite tiles (3/8"x12"x12") for a countertop re-facing. They didn't sell them with a bullnose so I bought extra in anticipation of either having them cut, bullnosed, & polished by a stone company or doing it DIY style.
If I go DIY, does anyone have a website or know-how in doing this? I am quite capable with tools and have access to a wide variety of them. I'm just curious what some of you "vets" might suggest...Thanks,
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 09-22-2011, 06:53 PM   #2
mossypath's Avatar
Bullnosed, & polished can run between $7 to $14 a linear foot. To make it yourself the tools will probably run you more than having it done but itís not that hard to do after you get the hang of it.
Or you could look at trims that will let you use stone and not have to bullnose.
http://www.schluter.com/media/WallCountertop-ENG.pdf
mossypath is offline   Reply With Quote
Old 09-22-2011, 07:15 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you have a wet saw you can buy a profiling wheel and make your own bullnose easy enough butt the profilers won't polish the edge after it tools it. Then...you need some sanding discs and a grinder and the attachments. Then you usually need some buffing equipment and some rouges.
The problem with making your own granite bullnose for a counter top is the bullnose edge of a counter top is very visual. You can't get away with a mediocre job like you could if you were using it anywhere but on a counter top.
Old 09-22-2011, 07:15 PM   #4
I likely have the tools, just not the applicators (sand paper of sorts?)...
I also have an already installed marble top that needs a bullnose and polish. It was a salvage from a demo home and the previous "wall edge" is now exposed.
Thanks for the link!!
Old 09-23-2011, 09:16 AM   #5
We posted at the same time, so I'm just seeing this now. I went youtube hunting and this seems to sum up all that I found: http://youtu.be/Ak6XnQCRy1E
I'm thinking I can do a good job, I've done great with wood in the past. Only one way to find out for sure is to grab the wheel and try out one edge. Is the sanding paper they speak of a special kind?
Old 09-23-2011, 09:24 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Silicone carbide (wet/dry) is typically the best. Garden variety aluminum oxide won't take the punishment or offer any life being used wet.
Here's one source I use. They also offer some "How-To" information in some areas.
http://www.tiletools.com
The Following User Says Thank You to Bud Cline For This Useful Post:
AGWhitehouse (09-23-2011)
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 10:08 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 11:49 AM
Granite not installed correctly???? debsc Kitchen & Bath Remodeling 7 02-01-2009 08:58 AM
