Going To Remove Part Of A Soffit, Worried About Wasps - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 05:49 PM   #1
going to remove part of a soffit, worried about wasps
How do you guys handle removing soffits, when you know there's a good chance that wasps are living above it? A couple years ago, I would always find those damn bees crawling in a gap between a porch lightbulb, and the soffit that the light sat in. I ended up putting on a bulb that had a thicker base, to close the gap, but I'm still worried about coming across bees up there. I need to run a piece of romex to the light, since it originally had K&T and I cut that off from the inside a year ago. Need a porch light sometime soon :P
Thanks!
Tonglebeak is offline   Reply With Quote
Old 04-18-2012, 07:23 PM   #2
Rewards Points: 210
Man I really dislike wasps!
Just get a broom and bump/bang the soffet in the area you plan on working. If nothing stirs then you're most likely ok. If some stir then you'll have to get some wasp spray (15-20ft) and spray them. Do it when the temps are cooler as they should all be present and less aggressive.
Good luck!
Ralph III is offline   Reply With Quote
Old 04-19-2012, 08:49 AM   #3
Seems like the best time to spray is early in the morning, everybody is home sleeping.
Mmfh is offline   Reply With Quote
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Wasps under deck..Part II. diyntn Pest Control 5 07-28-2009 06:13 PM
Soffit venting question dat5574 Roofing/Siding 2 03-03-2009 11:21 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 10:31 AM
Remove part of load bearing wall billyg Carpentry 2 02-25-2008 12:20 AM
